查看: 1414|回复: 1
大家来讨论一下遥控器设置吧:附遥控器设置之英文版
发表于 2003-8-28 08:12 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
[这个贴子最后由成都小财神在 2003/08/28 09:23am 编辑]
The radio is similar to the aircraft version. The biggest difference will be that the throttle and collective pitch will be mixed together. These two will also mix in yaw or rudder when the throttle is varied. This is know as anti-torque compensation. What happens is at a hover which is usually 1/2 throttle stick, there is a certain amount of pitch, usually 5 degrees. At this setting there will be needed a certain amount of tail rotor to correct for the amount of drag induced by the main blades, and the amount of opposite torque that the engine produces. So at this setting the tail rotor will be set to keep the nose straight. When there is more pitch added to the main blades by increasing the throttle, you get more drag and torque, so you will also need more tail rotor compensation to keep the nose straight. By taking away the pitch, there will be less drag and torque, so there will be less need for the added tail rotor input. If you have a helicopter with clockwise rotating blades, looking down on the helicopter, you will need right tail rotor from 1/2 throttle to full throttle, and left tail rotor from 1/2 down. This can be a little confusing because at 1/2 throttle you added to start a certain amount of right throttle and when you decrease the throttle you are really taking out that right tail rotor or going in the left direction.
Next you have extra switches on most helicopter radios for what is know as Idle - Up 1, maybe Idle - Up 2 and engine Hold. The idle up switches keep the engine at a certain level about 1/2 throttle to full throttle. This is for doing aerobatics. When you come down on the throttle stick, you will get a certain amount of negative pitch for loops, rolls, or even inverted flying. So since you don抰 want the engine to quite from being over loaded, the throttle will stay at a percentage to keep the main blades at that set rpm. For example, lets say that your pitch range was from a minus 5 degrees to a positive 8 degrees, and you hover at a positive 5 degrees. At this positive 5 degrees the throttle is at a 50% setting. When you come all the way down on the throttle stick you will a minus 5 degrees. This will in essence let you hover inverted so when you hover you will need that 50% throttle again. At 0 degrees pitch you will have the least amount of drag induced by the blades and you will need less throttle. So the final throttle curve will look like a "J". The low end will be at 50%, about 1/4 stick will have about 40% throttle, and 1/2 stick will have 50% throttle and full stick will have 100% throttle. The only difference between Idle - Up 1 and 2 will most of the time be the amount of pitch you will have or want at the low throttle stick position, this in turn will also need a different amount of throttle at the low stick position.
The Hold switch will take the engine to an idle position on the throttle and hold it there. By doing this the engine will still stay running but will let you have control of the collective pitch so you can practice your autorotations with the helicopter. The typical pitch settings will be about a minus 4 degrees to a positive 10 degrees. Both the top end pitch and low end pitch will very during test and set up of the helicopter.
Another two features the radio will most likely have is two knobs that will be called "Hovering Pitch" and "Hovering Throttle". What the hovering pitch knob will do is very the amount of pitch you have at you set hovering stick position. example would be if you hover at 1/2 stick position and at that position you had a positive 5 degrees pitch. When you vary this knob you might get lets say 4 degrees to 6 degrees of pitch. This will fine tune your helicopter so it will hover at exactly 1/2 stick position. The hovering throttle knob will do the same as the hovering pitch knob but it will do it only to the throttle. It will vary the throttle position or fine tune it at the 1/2 throttle position or where ever you have set that hover position to be. Yes there are some radios that will let you dictate where you want to hover at. Some people will set up for 3-D aerobatics by hovering at 3/4 stick. This will let them also hover inverted at the 1/4 stick position. By doing this the pitch and throttle curves stay more linear.
Beginners
normal idle up 1 idle up 2 hold
PITCH(deg)  -1, 5, +10  -2, 5, +9  -3, 4, +9  -4, 5, +10
THROTTLE(%)  0,25,50,75,100 50,25,50,75,100 70,40,55,80,100 idle
Intermediate
PITCH(deg)  -2, 5, +10  -2, 4, +9  -4, 3, +9  -5, 4, +10
THROTTLE(%)  0,25,50,75,100 70,40,55,80,100 80,40,60,80,100 idle
Advanced
PITCH(deg)  -2, 5, +10  -5, 3, +9  -9, 0, +9  -5, 4, +10
THROTTLE(%)  0,25,50,75,100 80,40,60,80,100 100,80,40,80,100 idle
For all the above it is what every pitch will hover with not to much or to little rpm in the head. This is typically at +4 1/2 to 5 degrees of main blade pitch. Typically about 1550 - 1600 rpms is about normal. If it gets to slow the helicopter will be sluggish and you can get in trouble with it in the wind. If its to fast it becomes touchy and will be hard to control.
* These are just some typical set ups. They will very between pilots. These will only get you started. If you don抰 use any negative pitch to start you end up with a helicopter that is like one with fixed pitch. And if you learn with what you will have later or close than the transition will not be a big thing later.
Terminology
Autorotation - This is the term for when the engine is either not running or is put into a idle position with the "Hold" switch.
ATS or Revolution Mixing, or Anti Torque Compensation - This is " Automatic Tail System". This refers to the radio mixing in a certain amount of tail rotor when the throttle / pitch is increased or decreased.
ATV or ENDPOINTS - This is "Adjustable Travel Volume". This refers to the amount of movement the servo has when the stick is moved from one extreme to another.
Collective Pitch - This is the ability to vary the main blade pitch when the throttle is increased or decreased.
Constant Drive Tail - This is a special autorotation clutch that will always drive the tail rotor even when the engine is off or in "Hold".
Curves - This is the end shape of the different funtions, like the "Pitch Curve", or "Throttle Curve". On the computer radio's you might have a 5 point curve. You will be able to set the low point, 1/4 point, 1/2 point or hover point, 3/4 point, and high point. Some radio's will have more and some less. At those particular points you can vary where the servo's output will be. On non computer radio's you should be able to at least control the low and high points.
Hold or Engine Hold - This is a switch that will take the engine to a preset idle position and will disengage the engine clutch. While in "Hold" though you will have full control of the "Collective Pitch". This allows you to practice "Autorotation" providing you have a autorotation clutch in your helicopter. This clutch will let the main blades free spin with out driving the tail rotor. There are certain conditions where you might want to drive the tail rotor. You can drive the tail rotor with special items called a "Slipper Clutch" or a "Constant Drive Tail".
Hovering Pitch - This is the amount of pitch you will need to hover the helicopter. On average this is about 5 degrees. Most helicopter radio's will have a knob on the transmitter to vary the amount of pitch at the present hovering stick position.
Hovering Throttle - This is the amount of throttle you will need to hover the helicopter. On average this is about 50% throttle. Most helicopter radio's will have a knob on the transmitter to vary the amout of throttle at the present hovering stick position.
Idle Up - This funtion is controlled by a switch and what it does is keep the engine speed at a present position when the throttle stick is lowered past that point. This way you can get into the negative range of pitch and will keep the blades spinning with out taking the engine to an idle. Some helicopter radio's will have either one or two "Idle - Ip's".
Inverted - This is when the helicopter is inverted and the funtions of the Pitch, Elevator, Rudder can be reversed by the use of the "Inver" switch or the pilot can do it him or her self at the sticks. This is refered to as "Switchless" inverted.
Slipper Clutch - This is another special unit that is attached to the autorotation clutch will let the main blades turn the tail rotor when the engine is off or in "Hold". The difference between this and a "Constant Drive Clutch" is that this one will "Slip" a little so the tail rotor while spinning will not load the main rotors as much while in the "Hold" funtion doing a "Autorotation".
 楼主| 发表于 2003-8-28 17:07 | 只看该作者
全英文哦,有点复杂
