查看: 1631|回复: 6
question about Kyosho EP Concept
发表于 2003-3-2 07:40 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
hello, anyone has EP Concept?
I have some question on it.
can I use a 4-channel transmitter to it ?
I mean "the motor" & the "pitch" are conbined with using 1 channel only .
is it possible to do it ?
发表于 2003-3-2 09:07 | 只看该作者
I am not sure.
My advise is to buy the best RC which you can afford.
If you are not in China, there are a lot e-heli better than EP.
发表于 2003-3-2 17:04 | 只看该作者
理论上可以,但是EP的桨距必须精确调节,否则不好飞。若与油动连动,则无法达到精确调节的目的。EP对桨距的变化非常敏感,调好了省电又好飞,调不好对马达磨损就较大,而且飞行时间短。
 楼主| 发表于 2003-3-2 20:45 | 只看该作者
again..
How about fixed the "pitch" in the highest postiton by
a "no-connected" servo ? just like Feda & Smartech Heli....?
发表于 2003-3-2 22:31 | 只看该作者
当然可以,但不建议。你可以找一个坏掉的舵机装在上面,以舵机的牵阻来讲,应该能够把桨距固定住。
 楼主| 发表于 2003-3-2 22:50 | 只看该作者
I see, thank you for all answering my question ^_^
 楼主| 发表于 2003-3-4 02:18 | 只看该作者
thanks  a lot, I just want to find some "RC discuss board" in engligh..
haha..www.rcgroups.com is avery good place.
do you have any more sites ? ^_^
