查看: 1417|回复: 1
【求助】 片身小飛機不能滑行? 請幫幫忙
发表于 2006-5-4 00:01 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
B)請求幫忙! 為什么我的片身小飛機不能滑行?
最近看到的一個好漂亮的片身機,打算做來玩玩
如圖:我不知道它能不能很好的滑行…………(從 彰化 的bird of prey 和 c-47 試飛得到知,一定要很好的滑行才好飛!)
我自己做的小飛機是沒有按圖紙的比例呎吋的,靠感覺量呎吋,只是彷它的外形
如圖:我是用5.0mm 的珍珠版做的,沒有加補強和設備 (空機身只加了一個小硬幣作加重 和 配重心用)
做好外行和初步定好重心后試飛,結果不能滑行………………
不知道為什么,重心前移0.5-1 cm 飛機就會馬上掉下來(從最好的地方后移0.5-1 cm 飛機就馬上尾鏇!)
重心最好的時候飛機只能飛 2-2.5 m 就又進入尾鏇了 (無風,飛機斜上30-40 度 出手)
我是根據 彰化 的bird of prey 和 c-47 試飛得到到的結論的,他們做的飛機在不開動力時 滑行性很好
現在我的小飛機沒有加設備和motor,為什么不能滑行呢?是我的重心錯嗎?
還是我的飛機太輕?我加上混控、理電和電機后不開動力會滑好嗎???
謝謝大傢的幫忙!
PS:这是在rcgroups上有一位朋友给我的回复,我在 第四点建议 上有点不懂,也请各位帮帮忙啦~~!!:em21:
Canard designs can be tricky. Here's some ideas:
1. Angles. Let's say your main wing is at 0 degrees. Your canard needs to be angled positive to that. You want the canard to push the nose up.
2. CG. You still need to "fly" the model on the main wing. The CG on a canard model will be really far aft.
3. Weight. The model needs to have some weight to it to fly. If the wing loading is too light, it'll act strange. Grab a balance scale and make a balast that weighs about as much as your gear. That'll bring the model up to 20 grams or so. Then set the CG.
4. Gliding. I'm going to assume that you have glided models before. You should be throwing it downwards vice upwards。Think about the angle you'd like to see the model glide at when you turn off the motor. Then, adjust the CG and the canard angle till you get that angle on the throw. For most models, look for a 3 to 1 glide angle。If you are 2 meters tall, aim for a point 6 meters in front of you. Give it a good, hard toss too.
Good luck.
Oh, and for inspiration, look for a 3-view of the Beechcraft Starship. Or Chuck Yegar's Ez models.
发表于 2006-5-4 23:55 | 只看该作者
头轻了
字节字节字节字节
