查看: 830|回复: 0
关于microminiosd的问题
发表于 2016-11-4 21:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
买了一个micro miniosd,需要支持F3,卖家给了mavlink协议的,也就是APM协议的,只能自己重新刷固件了,但是刷的时候遇到问题了,该怎么选择,有人知道吗?
第一个 OSD硬件的选择,应该选择micro miniosd对的吧?
/********************       OSD HARDWARE settings      *********************/
//Choose ONLY ONE option:
//#define MINIMOSD                    // Uncomment this if using standard MINIMOSD hardware
#define MICROMINIMOSD             // Uncomment this if using the MICRO MINIMOSD hardware
//#define RTFQV1                    // Uncomment this if using standard RTFQ/Witespy V1.1 OSD, select this to correct for both swapped bat1/bat 2 and to also use alternative resistors / pinouts.
//#define RTFQMICRO                 // Uncomment this if using micro RTFQ/Witespy Micro Minim OSD, select this to correct for swapped bat1/bat 2.
//#define RUSHDUINO                 // Uncomment this if using Rushduino
//#define KYLIN250PDB               // Uncomment this if using a Kylin 250 FPV PDB (Using A6 as VOLTAGEPIN)
//#define AIRBOTMICRO23             // Uncomment this if using an airbot MicroOSD v2.3
第二个是波特率,默认全部注释掉了,是否需要选择115200?
/******************** Serial speed settings *********************/
// Overides defaults if required (57.6k for MAVLINK based or 115k for all others).
//#define BAUDRATE 115200
//#define BAUDRATE 57600
//#define BAUDRATE 38400
//#define BAUDRATE 19200
//#define BAUDRATE 9600
