查看: 676|回复: 3
第一次用变频控,碰到我问题请教了
发表于 2009-6-13 16:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
第一次用变频控,碰到我问题请教了
第一次用只知道怎么对频,去的飞行场要挂频率牌的却只知道是72兆的,高频头的变频设置成5*10  2*1(52),高手们这个是什么频率,我不知道怎么算啊
发表于 2009-7-9 13:53 | 只看该作者
72.830
Channel 11        72.010 MHz        Channel 36        72.510 MHz
Channel 12        72.030 MHz        Channel 37        72.530 MHz
Channel 13        72.050 MHz        Channel 38        72.550 MHz
Channel 14        72.070 MHz        Channel 39        72.570 MHz
Channel 15        72.090 MHz        Channel 40        72.590 MHz
Channel 16        72.110 MHz        Channel 41        72.610 MHz
Channel 17        72.130 MHz        Channel 42        72.630 MHz
Channel 18        72.150 MHz        Channel 43        72.650 MHz
Channel 19        72.170 MHz        Channel 44        72.670 MHz
Channel 20        72.190 MHz        Channel 45        72.690 MHz
Channel 21        72.210 MHz        Channel 46        72.710 MHz
Channel 22        72.230 MHz        Channel 47        72.730 MHz
Channel 23        72.250 MHz        Channel 48        72.750 MHz
Channel 24        72.270 MHz        Channel 49        72.770 MHz
Channel 25        72.290 MHz        Channel 50        72.790 MHz
Channel 26        72.310 MHz        Channel 51        72.810 MHz
Channel 27        72.330 MHz        Channel 52        72.830 MHz
Channel 28        72.350 MHz        Channel 53        72.850 MHz
Channel 29        72.370 MHz        Channel 54        72.870 MHz
Channel 30        72.390 MHz        Channel 55        72.890 MHz
Channel 31        72.410 MHz        Channel 56        72.910 MHz
Channel 32        72.430 MHz        Channel 57        72.930 MHz
Channel 33        72.450 MHz        Channel 58        72.950 MHz
Channel 34        72.470 MHz        Channel 59        72.970 MHz
Channel 35        72.490 MHz        Channel 60        72.990 MHz
发表于 2009-7-12 20:01 | 只看该作者
学习了
发表于 2009-7-20 21:56 | 只看该作者
还是2.4G!:em15:
