查看: 7250|回复: 16
[室内机] 如果是8.5mm空心杯和7mm空心杯的动力会相差多少
发表于 2011-5-28 09:22 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
看见parkzone 和eflite的微型机使用的都是8.5mm空心杯电机减速组,1s电,甚至可以飞重35g左右的3D机。不知兄弟们是否尝试过?
发表于 2011-5-28 09:45 | 只看该作者
呵呵。抢沙发
发表于 2011-5-28 09:49 | 只看该作者
给个链接看看:em05:
 楼主| 发表于 2011-5-28 10:00 | 只看该作者
http://www.parkzone.com/Products/Default.aspx?ProdID=PKZU1080
Ultra Micro Sukhoi SU-26xp BNF
This Sukhoi design features a powerful propulsion system and large control throws that deliver impressive precision aerobatic performance.
More Photos
Spektrum AR6400L 6-Channel DSM2 Receiver/ESC/Servos Unit
Powerful 8.5mm coreless motor adds improved performance
Vibrant XP trim scheme
Carbon rod-reinforced horizontal stab
Molded pushrod guides
Comes out of the box completely assembled
Large control throws for increased precision
The Sukhoi SU-26xp takes everything that made the Sukhoi SU-26m ultra micro a hit and adds a more powerful motor, new propeller and larger control throws for even more aerobatic excitement. Best of all, you can have it flying in as little time as it takes you to charge its battery and bind it to a DSM2™ transmitter (exponential and dual rate functions recommended).
http://www.e-fliterc.com/Products/Default.aspx?ProdID=EFLU1080
Wingspan: 16.8 in (427mm)
Overall Length: 19.4 in (494mm)
Wing Area: 74 sq in (4.8 sq dm)
Flying Weight: 1.2 oz (32.5g)
Motor Size: 8.5mm Coreless Brushed
Trim Scheme Colors: Red, Grey, Clear, Black
Prop Size: 130mm x 70mm
Recommended Battery: 3.7V 1-Cell 150mAh LiPo (included)
Approx. Flying Duration: 4-8 minutes
Scale: Ultra Micro
Minimum Age Recommendation: 14 years
Experience Level: Advanced
Recommended Environment: Indoor
Assembly Time: Less than 1 Hour
Is Assembly Required: No
[ 本帖最后由 subsub 于 2011-5-28 10:35 编辑 ]
发表于 2011-5-28 10:41 | 只看该作者
差距大很正常啊,7mm减速组比6mm减速组能差将近两倍的推力,8520空心杯电机是类似华科尔那种最小直升机的主电机,一般那种直升机要35g左右,所有飞3D很正常。
 楼主| 发表于 2011-5-28 10:56 | 只看该作者
xiphorix可以开发产品了,我去查了大概就是 msr主机或260小直机的主电机。
发表于 2011-5-28 11:26 | 只看该作者
:em18: 说的很轻松啊,动不动上万的模具费啊,还是让圆梦的手工来吧,不过倒是正准备上这种电机。
发表于 2011-5-28 11:37 | 只看该作者
PZ的8.5减速组看似很不错,坛内几位设备供应商快组织点货源吧,兄弟们等着进货呢。:em15: :em15: :em15:
发表于 2012-7-20 16:40 | 只看该作者
8.5的空心杯,现在很火的伟力v929不就是用的这个么
发表于 2012-7-20 17:55 | 只看该作者
就是8.5mm的减速组应该出一些..
7mm的搞不成低不就..减速组上5030很烫的..
发表于 2012-7-20 17:58 | 只看该作者
不过8.5mm电机可以用现在市面的上的一种7mm扩孔来做.
我做了一台机就是这么做的
发表于 2012-7-20 21:58 | 只看该作者
我入模的头两架飞机就是parkzone和eflite的飞机, 就是这种8.5mm空心机电机, 动力很够, 不过最大的问题是寿命. 一般飞行时间在10-20小时就不能用了.
发表于 2012-7-21 01:17 | 只看该作者
对.我那个电机差不多也10多小时就出问题了..时不时在大油门下尖叫一下子..:em15:
 楼主| 发表于 2012-7-21 07:54 | 只看该作者
空心杯我拆过,估计还是电刷部分磨损导致的
发表于 2012-7-22 07:23 | 只看该作者
我觉得短命原因是电机所带的负载太大,解决办法:1.尽可能的利用减速组提升拉力 (减速比最好1:10以上)2.控制机体重量和机翼面积减少飞行阻力3.根据所需拉力和飞行速度控制好桨径和螺距(原则是拉力够用就行不要太贪心,有刷电机一般只适用于休闲的慢速机,这种飞机桨要求是大直径小螺距快速机反之,当然成品桨有诸多限制,最好是能自制)。 4。假如是仓身飞机还要做好电机仓的通风。通过以上措施电机的寿命就有望大幅 提高。:em15: :em15:
[ 本帖最后由 phl9516 于 2012-7-22 07:41 编辑 ]
发表于 2012-7-22 08:18 | 只看该作者
用了n年的空心杯,时间证明是刷磨损造成的,减速组只是延缓了刷磨损:em15:
发表于 2012-7-25 16:57 | 只看该作者
帮你贴图
迷你3D 机 E-flite Ultra-Micro 4-Site
[ 本帖最后由 sundays1977 于 2012-7-25 17:10 编辑 ]
