查看: 8482|回复: 50
FPV 遥控UHF神器到了,还是选靠谱的,刚开苞图
发表于 2012-9-30 19:27 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
介绍:
The EzUHF transmitter is a true powerhouse with a wealth of connectivity broadening the horizon for each FPV pilot. Headtracking support has now been taken out of the hands of the RC transmitter and is exclusively handled by the EzUHF transmitter, so any radio can be used with your TrackR2 now. Support for any radio battery voltage is guaranteed as well, as the EzUHF transmitter has a power-in jack which will accept a 3S LiPo, so no soldering in your precious RC transmitter is required. For Futaba systems using a 9.6V battery or 3S LiPo the EzUHF transmitter can be powered directly from it, with just a single cable. The battery voltage, either from the external battery, or provided by the radio, obviously is monitored and an audible alarm will sound when the battery gets low.
The EzUHF transmitter comes with an auxilary input that’ll offer exciting upcoming new features for FPV/UAV use. The EzUHF transmitter also comes with a power boost switch, which boosts the power if you happen to put yourself in a tight spot and need to regain control. And we’ve not even touched upon the full duplex capabilities of the EzUHF solution, which is exclusively available on the EzUHF transmitter and the 8-ch EzUHF receiver, turning both into full blown transceivers and hence opening the door for exciting future possibilities.
these clips may work to clip it to your radio handle!
-Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
-433MHz/70cm Ham band operation
-GFSK modulation
-600mW (~28dBm) output power
-Direct head-tracker input, adding head-tracker compatibility to most radios
-Power switch, boost power when at long range
-Standard SMA antenna connector, compatibility with 70cm antennas
-Flexible buffered, AC-coupled, PPM input, ensures compatibility with 3.3v thru 9.6v PPM levels
-Standard USB port (Mini-A) for firmware upgrades, and system configuration
-Single pushbutton learning of failsafe positions
-Binding function, which allows binding Single Tx->Rx, Multi Tx->Rx, and Single Tx->Multi Rx
-Mates with 8 channel, and 4 channel EzUHF receivers
-Power sourced directly from the R/C Tx (Futaba), or optional DC power jack
-Built in receiver, for future expansion
-Custom extruded brushed aluminum enclosure
发表于 2012-9-30 19:39 | 只看该作者
学习中
发表于 2012-9-30 19:45 | 只看该作者
来个链接,介绍一下产品啊.这东西估计FPV非常好
发表于 2012-9-30 19:47 | 只看该作者
这是什么啊
发表于 2012-9-30 19:54 | 只看该作者
这是嘛?
发表于 2012-9-30 19:55 | 只看该作者
immersionRc 和托马斯V6哪个好??
楼主那他飞固定翼还是多轴?
发表于 2012-9-30 20:13 | 只看该作者
这是嘛
发表于 2012-9-30 20:14 | 只看该作者
好在哪
发表于 2012-9-30 20:17 | 只看该作者
能不能给个详细的介绍啊?
发表于 2012-9-30 20:23 | 只看该作者
发表于 2012-9-30 20:24 | 只看该作者
发表于 2012-9-30 20:40 | 只看该作者
光发贴不介绍?
发表于 2012-9-30 20:45 | 只看该作者
不知道是什么!
发表于 2012-9-30 20:46 | 只看该作者
发表于 2012-9-30 20:52 | 只看该作者
发个图 也不说明一下 欺负我们新手啊!
发表于 2012-9-30 20:57 | 只看该作者
发表于 2012-9-30 21:21 | 只看该作者
第几代的? 我要也准备入手了
发表于 2012-9-30 21:23 | 只看该作者
发表于 2012-9-30 21:35 | 只看该作者
是功放吗?
