以前我发过家用型的 那这个应该算模型级的了 真佩服国人 也不知道鬼佬怎么得到的 现在卖380美元 价格挺不错的 可惜在地球的另一边:em15:
http://cgi.ebay.com/Small-Bench-Milling-Machine-/230531141009?pt=LH_DefaultDomain_0&hash=item35acba0d91
Mill made in Taiwan in 1984. I have used it for milling aluminum, brass, and various plastics. I have now acquired a larger vertical mill as I will be milling steel. It is a compound mill as it tilts +/- 30 degrees foward and back, tilts sideways +/- 30 degees, and the X table can be turned by +/- 45 degrees. The mill head has 4" of back and foward travel.
Motor is 2 HP wired for 115 volts with a maximum current of 12 amps. The motor has been rewound and required the pressing of two switches to start it.
The mill operates smoothly and I have had No problems with it in the three years that I have owned it.
Collet size is R8 the same as for a Bridgeport and most newer mills.
Table size 19.5"X 5"
X travel 10"
Y travel 7"
Z travel quil 2.5"
Z travel column 7"
Maximum height from collet to table is 9"
1984年在台湾制造机。I have used it for milling aluminum, brass, and various plastics.我已经用它来加工铝、黄铜、各种塑料产品。I have now acquired a larger vertical mill as I will be milling steel.我已经获得了更大的立磨我将铣削钢。It is a compound mill as it tilts +/- 30 degrees foward and back, tilts sideways +/- 30 degees, and the X table can be turned它是一种复合机为它倾斜+ / - 30度,一边倾斜,提出+ / - 30 degees、X表可以转by +/- 45 degrees.通过+ / - 45度。The mill head has 4" of back and foward travel.磨坊头有4”的提出旅游。
Motor is 2 HP wired for 115 volts with a maximum current of 12 amps.电机为115伏2点兴奋与电流安培的12个。The motor has been rewound and required the pressing of two switches to start it.电机已被当场而紧迫的两个开关启动它。
The mill operates smoothly and I have had No problems with it in the three years that I have owned it.工厂运转平稳,我没有问题的三年里,我拥有它。
Collet size is R8 the same as for a Bridgeport and most newer mills.R8的大小是夹同一Bridgeport和大多数新工厂。
Table size 19.5"X 5"工作台面积195“X”
X travel 10"10“X旅行
Y travel 7"7“Y旅行
Z travel quil 2.5"quil Z旅行2.5吋的。
Z travel column 7"Z旅游专栏7 "
Maximum height from collet to table is 9"最大的高度,桌子是9 "夹
[ 本帖最后由 christzyy 于 2010-9-28 19:47 编辑 ] |
