翼众不同 发表于 2013-3-13 02:24
第二个网址啊。很多东西要注册了才能看啊
不过我还是找不到油门锁啊
我看了不要注册,链接复制就能打开。
油门锁就是在混控里面,自己用语法什么写出来的。。。
我复制了下第二个论坛里面有人说的“
Okay here it is. Using ER9x software.
Throttle on channel 3, go to Mixer and scroll to channel 3, add new mix in channel 3 as follows:
Source= MAX
Weight= -100
Ofset= 0
F1Modetrim= OFF
Trim= ON
Curves= ---
Switch= THR
Warning= OFF
Multplx= REPLACE
Delay Down= 0
Delay Up= 0
Slow Down= 0
Slow Up= 0
Now when you flip the throttle switch it overrides the stick. One note of caution...DO NOT EVER REVERSE THE THROTTLE NOW. IF YOU DO, WHEN YOU FLIP THE SWITCH THE THROTTLE WILL GO TO FULL POWER.
我不知道对与错。你自己试试了
