查看: 1210|回复: 3
MWC更新鸟。。。2.2 r1514
发表于 2013-7-5 08:56 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
更新内容看https://code.google.com/p/multiwii/source/list
下载:https://multiwii.googlecode.com/ ... 013_07_05_r1514.zip
代码的不懂。
不过config.h看到这个:
  1. /* I2C GPS device made with an independant arduino + GPS device
  2.        including some navigation functions
  3.        contribution from EOSBandi   http://code.google.com/p/i2c-gps-nav/
  4.        You have to use at least I2CGpsNav code r33 */
  5.     //#define I2C_GPS
  6.     // If your I2C GPS board has Sonar support enabled
  7.     //#define I2C_GPS_SONAR
复制代码
 楼主| 发表于 2013-7-5 08:59 | 只看该作者
电机、桨动平衡????
  1.   /********************************************************************/
  2.   /****           Dynamic Motor/Prop Balancing                     ****/
  3.   /********************************************************************/
  4.   /*                   !!! No Fly Mode !!!                            */
  5.
  6.     //#define DYNBALANCE   // (**) Dynamic balancing controlled from Gui
  7.   /********************************************************************/
  8.   /****           Regression testing                               ****/
  9.   /********************************************************************/
  10.     /* for development only:
  11.        to allow for easier and reproducable config sets for test compiling, different sets of config parameters are kept
  12.        together. This is meant to help detecting compile time errors for various features in a coordinated way.
  13.        It is not meant to produce your flying firmware
  14.        To use:
  15.        - do not set any options in config.h,
  16.        - enable with #define COPTERTEST 1, then compile
  17.        - if possible, check for the size
  18.        - repeat with other values of 2, 3, 4 etc.
  19.         */
  20.     //#define COPTERTEST 1
复制代码
发表于 2013-7-5 09:56 | 只看该作者
发表于 2013-7-5 10:25 | 只看该作者
更是更了!就不知道和上一版本有多大区别!有空回去飞飞
