查看: 2764|回复: 11
想配一架最小的4S电暴力穿越机,请高手指教~~~~~~~
发表于 2015-5-6 09:56 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
如标题~~~玩航模10年。什么都飞过了。最近也在飞小的250穿越机。可是看到老外视频后发现自己小250还不够爆。说现在老外都上4S电了。所以也想装一架4S电的小4轴。想用330机架。不知道用什么电机?什么桨。才能飞的更快更爆。请高手们给点见意。谢谢。
发表于 2015-5-11 23:36 | 只看该作者
tieshitou 发表于 2015-5-11 15:18
Lumenier QAV250 carbon fibre edition http://www.getfpv.com/multi-rotor-frames/qav250-mini-fpv-quad/q ...
老外的好贵呀
 楼主| 发表于 2015-5-11 18:22 | 只看该作者
谢谢。学习了。
发表于 2015-5-11 15:18 | 只看该作者
Lumenier QAV250 carbon fibre edition http://www.getfpv.com/multi-roto ... -fiber-edition.html
QAV250 10° Motor Tilt kit http://store.ivc.no/product/qav250-tilt10
Naze32 flight controller http://www.getfpv.com/flight-con ... ht-right-angle.html
KISS 18A ESCs http://www.getfpv.com/electronic ... 8-amp-esc-2-4s.html
Lumenier FX2208-9 2000kv motors http://www.getfpv.com/multi-roto ... x2208-9-2000kv.html
HQ 5x4.5 bullnose props http://www.getfpv.com/hqprop-5x4 ... e-2-pack-black.html
Lumenier CS-600 super camera http://www.getfpv.com/lumen
ImmersionRC 5.8ghz 600mW Vtx http://www.getfpv.com/5-8ghz-600mw-video-tx.html
Circular Wireless SPW58 5.8GHz http://www.getfpv.com/circular-w ... -90-degree-sma.html
Lumenier 1300mAh 4s 60c Lipo Battery http://www.getfpv.com/batteries/ ... o-battery-xt60.html
Gopro Hero 3+ black 1080p 60fps http://www.getfpv.com/gopro
Frsky D4R-II receiver http://www.getfpv.com/radios/receiver...
FrSky Taranis 2.4ghz transmitter http://www.getfpv.com/radios/rec ... er-w-telemetry.html
Fatshark Attitude SD 2 goggles http://www.getfpv.com/fatshark-attitude-v2.html
Circular Wireless SPW58 5.8GHz Antenna http://www.getfpv.com/circular-w ... w-90-degree-sma.htm
Naze32 settings
CleanFlight
Firmware Version 1.8.1
PID controller 2 - LuxFloat
oneshot125 enabled
Looptime 1200
Roll P 1.2 I 0.045 D 16
Pitch P 2.0 I 0.050 D 20
Yaw P 3.3 I 0.036 D 0
Roll rate 0.65
Pitch rate 0.65
Yaw rate 0.43
TPA 0.00
RC rate 0.75
RC expo 0.70
throttle expo 0.00
发表于 2015-5-11 09:16 | 只看该作者
peidehua521 发表于 2015-5-11 09:06
很牛啊。看着不错。有暴力飞的视频吗。呵呵
没买808。。。。回头周末用肥鲨V2自带的DVR试试效果
 楼主| 发表于 2015-5-11 09:06 | 只看该作者
pzpz 发表于 2015-5-6 14:51
1800  40C   买花牌1800 40C 6S拆
发表于 2015-5-6 14:51 | 只看该作者
cisforcer 发表于 2015-5-6 09:59
随便什么机架   能上 6寸桨 的机架
然后 电机2206 或者 228
发表于 2015-5-6 14:28 | 只看该作者
试试双天4S 1750maH,45C,197g,60C的小电池很难买到
发表于 2015-5-6 12:00 | 只看该作者
国内4S电池买不到小的啊
最小也要1800
发表于 2015-5-6 10:05 | 只看该作者
2000KV  或者 1900KV
 楼主| 发表于 2015-5-6 10:03 | 只看该作者
随便什么机架   能上 6寸桨 的机架
然后 电机2206 或者 228
2206KV多少呢?
发表于 2015-5-6 09:59 | 只看该作者
随便什么机架   能上 6寸桨 的机架
然后 电机2206 或者 228
桨用 7 寸 或者 8 寸桨, 剪短 到 6寸
电池用 1300  60C ,估计买不到
1800  40C ,估计也买不到
电调 20A
这样肯定暴力了 。。。祝你炸鸡
