查看: 2744|回复: 17
$500 5月10日 要发布connex 720P高清数字图传了
发表于 2016-4-27 02:41 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
定价在$500
他们是和connex hd 合作 还是直接拿货不知道
宣称60fps, 0延迟(低于1ms), you管子上有演示视频 效果并不好
这是给穿越机用的 功率应该不大但是体积应该会很小
hobbyking 宣称 这是 类似70mhz 去2.4G的进化
5.10 一出 我马上买一个来看看 5.13 之前就可以拿到
模拟的接受发射机准备降价吗
国内其他厂家的高清图传也要加油了
connex 说图传是带720P摄像头的 The video is captured with the 720P camera that will be part of the HD system
Getting the HD link is just the first step, one of the key factors was to keep it small. at 45gr. for the Tx+ HD camera we were able to keep the size to the minimum.
The size of the camera is: 28x20x27 mm and the transmitter is at: 70 x 36.5 mm
Tx 端带720P摄像头 摄像头尺寸28x20x27 mm 发射机70 x 36.5 mm 共重45g
https://www.foxtechfpv.com/conne ... d-kit-preorder.html
Features:
- Uncompressed 720P High-Definition over a Digital-Link
- Support range of up to 1000ft/300m LOS
- Keeping zero latency, real-time video at all ranges
- 30 available HD channels over 5.8GHz (5.1GHz-5.8GHz) with easy to set options
- Offering solution for the novice racer as well as high-end racing
- Providing a spectators mode
- Built-in OSD capabilities
- Region-less Tx compatible with any Rx
- Mobile App configuration tool over bluetooth
Amimon New FPV Zero-Delay Camera features:
- HD 720P camera
- FPV optimized for indoor&outdoor flights
- Advanced hight-dynamic-range supported
- Dimensions-28x20x27mm
- 105 degree FOV with fixed lens
- Compatible with vision transmitter only
- Power up from vision transmitter
- Weight is 13g, 6g for the camera and 7g for the lens
Amimon New FPV Zero-Delay Transmitter specifications:
- Power consumption: 3.5W
- Power input: 6V-15V, 2S-4S battery supported
- Antennas: two external MMCX connectors
- Weight: 30g
- UX: 2 LED- status indication only
- Interface: Power in (4pins)
                Power out to the camera&recorder
                Micro USB-connection to application; wired pairing
                Proprietary MIPI(14pin right-angle,JST SM20B-SRSS)-HD video input
- Environmental: Operating temperature: -10°to 50℃
                       Operating humidity: 10%-90%
                       Storage temperature: -10°to 75℃
Receiver specifications:
- Power consumption: 3-3.5W
- Power input: 6-28V, 2S-6S battery supported, reverse polarity protected
- Antennas: 5 antennas(5 external short SMA connectors)
- UX: 2 LED-status indication only;3 push button-for OSD control
- Interface: Power supply jack
                 HDMI out- type A female
                 Bluetooth for application management control
Management application:
- Android & iOS Applications
- Bluetooth connectivity from mobile APP to vision ground unit
- Setting your device easily: Manual frequency setting
                                      Regulatin&regional setting
                                      Race mode for setting up races
- Built-in OSD-provides full functionality of OSD menu&buttons:
  recording
  choosing who to watch
  Configuration of recorder, wireless setup&OSD
Your purchase includes:
- 1*Camera
- 1*Transmitter
- 1*Ground unit
- 1*Package of accessories
发表于 2016-11-29 11:46 | 只看该作者
 楼主| 发表于 2016-5-5 05:40 | 只看该作者
到手后 肯定第一时间挂QAV500 上试试
问题好像我手上没有hmdi 的录像设备
发表于 2016-4-28 22:28 | 只看该作者
火钳刘明
发表于 2016-4-28 15:58 | 只看该作者
非常期待楼主放出实际测试视频,这万一多少g,能用在穿越上吗
 楼主| 发表于 2016-4-28 06:07 | 只看该作者
美国另外一家零售getfpv 也有一点消息了
主要市场是给racing quad 用的
配套的接收器和摄像头还完全不清楚是什么情况
有人说是配套Eachine的屏幕 如果光屏幕有可能
头像被屏蔽
发表于 2016-4-27 12:18 | 只看该作者
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2016-4-27 10:57 | 只看该作者
什么鬼?
发表于 2016-4-27 10:27 | 只看该作者
0延迟!老外吹牛的功夫还真不输给国人...
发表于 2016-4-27 10:00 | 只看该作者
没有任何设备能做到0延时
发表于 2016-4-27 09:44 | 只看该作者
强势关注
发表于 2016-4-27 09:14 | 只看该作者
发表于 2016-4-27 08:56 | 只看该作者
视频我从油管搬过来了。。
发表于 2016-4-27 08:49 | 只看该作者
Something ground breaking is on the horizon and its set to alter the FPV Racing scene.
Are you?
• Tired of being shot out of the sky due to poor video signal or interference during a race?
• Looking for an HD Digital solution with no latency problems?
• Need on board recording without having to carry a bulky action cam?
• Would you love to fly with twice as many pilots than what you can now
Buckle up! FPV Drone Racing is about to change forever, HD, Digital, Zero Latency FPV Video for FPV Drone Racing. Connex is changing the game in FPV drone racing taking to a new era.
Despite its fast growing popularity, FPV drone racing has been dogged by technical challenges limiting wider spread adoption and use. Connex addresses those head on with mind-blowing realism and accuracy in video transmission and vision.
Think analog versus digital TV. Dial-up versus fiber optic. That’s what we’re talking about. The sport will never be the same.
This game changing technology will be available here at Hobbyking so keep checking the coming soon page for more information and stay tuned for May the 10th!
Register your interest by entering your email below.
发表于 2016-4-27 08:26 | 只看该作者
请问人世间还有什么设备能做到零延迟?
发表于 2016-4-27 08:13 | 只看该作者
0延时,300美金。。。。。都是亮点啊。
发表于 2016-4-27 07:57 | 只看该作者
延迟是必须的
发表于 2016-4-27 07:03 | 只看该作者
消息够水的。。。。。。
