查看: 1575|回复: 7
请问,d7e 加两个两段开关怎么接线?????
发表于 2017-5-15 18:48 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
d7e 加两个两段开关怎么接线?????发个图或者给个教学贴谢谢各位啦……
 楼主| 发表于 2017-5-16 15:06 | 只看该作者
shaker 发表于 2017-5-15 22:09
The other day while reading the "Devo 7e Hardware Connections" to the part of the Button Matrix, to  ...
Thank U very much indeed!
发表于 2017-5-16 01:41 | 只看该作者
楼上贴了两段开关的安装方法,我自己装的是三段开关,这里也分享一下加三段开关的方法吧(图片版权归原作者所有:https://www.rcgroups.com/forums/ ... 3-position-switches):
发表于 2017-5-15 22:16 | 只看该作者
更多的Devo7e Mod看 这里
发表于 2017-5-15 22:09 | 只看该作者
The other day while reading the "Devo 7e Hardware Connections" to the part of the Button Matrix, to my amazement I found two unused buttons left over in the originl design.
www.deviationtx.com/articles/18-devo-7e-hardware-connections
Since the 7e is coming short of switches (that limits 7e to being a plain 6 Channels Tx, or even worse a 4 Channels Tx only if both the existing switches are assigned as "Hold" , "FMOD", "D/R"), I think it would be nice if we can make use of the two left over button matrix.
After some discussion with PB and with his kind help (he always is, isn't he?) and a bit of very easy hardware mod, the upgrade work is done and now we have a plain 8 Channel 7e Tx.
The mod goes on like this:
1. Open the Tx case, take out the four screws that hold the main PCB
2. Flip the PCB over and we can see the buttons and the wire connectors. Carefully identify the spots as shown in the photo and solder three wires perferably of different colors say Red, Yellow and Orange.
3. The schematic diagram :
4. On the Tx front cover, drill out two holes to the size of the switches you are going to use and put the switches on. Left is "Elevator D/R" and right is "Aileron D/R).
5. Connect the other end of the Red wires (you have to make a parallel connection) to the middle (toung) of both switches.
6. Solder a diode to the top contact of both switches. Pay attention to the direction of the diodes. Different doide types have different appearance. The one I am using is a low voltage rectifier 1N4001 but whatever diode type should also works. The point is to make sure current is flowing from the Yelow/Orange to the Red wire.
That's all for the hardware mod. Of course you have to upgrade to the latest fw in order for the switches to work. The one I am using now is:
www.deviationtx.com/media/kunena/attachm...ang_2013-02-12-3.zip
Thanks again to PB's patience and hardwork to make it a reality...
发表于 2017-5-15 20:28 | 只看该作者
发表于 2017-5-15 19:48 | 只看该作者
同问D12两段开关怎么换三段开关?
发表于 2017-5-15 19:16 | 只看该作者
同问,D10两段开关怎么换三段开关?
