查看: 2908|回复: 10
Arduino XBee 10公里 数传能和FY-21AP 兼容吗?
发表于 2011-3-3 09:56 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
Arduino XBee Pro 900 U.FL Connection Zigbee10公里传输无线数传模块
Xbee模块是采用ZigBee技术的无线模块,通过串口与单片机等设备间进行通信,能够非常快速地实现将设备接入到ZigBee网络的目的。
sku: WRL-09098
Description:The XBee-PRO 900 RF module is ideally suited for low-latency point-to-multipoint networking applications. Capable of point-to-point, peer-to-peer and point-to-multipoint networking, the XBee-900 is ideal for solutions where RF penetration and absolute transmission distance are paramount to the application.
As a member of the XBee family of RF products, the module is easy-to-use, shares a common footprint, and leverages Digi’s Drop-in Networking solutions including gateways and adapters. No configuration is necessary for out-of-the-box RF communications. The module’s default configuration supports a wide range of data system applications. Advanced configurations can be implemented using simple serial AT commands.
XBee-PRO modules operate within the ISM 900 MHz frequency band. The modules are optimized for use in US and Canada.
Digi Part #: XBP09-DPUIT-156
Features:
  • 3.3V @ 210mA
  • Fast 156 Kbps RF data rate
  • 50 mW (+17 dBm) power output
  • Up to 6 miles (10 km) RF LOS with high gain antennas
  • Point-to-multipoint networking ideal for low-latency applications
  • Support for large, dense networks
  • 128-bit AES encryption
  • ISM 900 MHz operating frequency
  • U.FL connector
  • Industrial temperature rating (-40° C to +85° C)
  • Advanced mesh networking and low-power modes supported
  • Approved for use in the United States and Canada
Documents:
  • Digi XBee Pro 900 Page:[url=]http://www.digi.com/products/wireless/point-multipoint/xbee-pro-900.jsp[/url]
  • Datasheet:[url=]http://www.sparkfun.com/datasheets/Wireless/Zigbee/XBee-900-Datasheet.pdf[/url]
  • Product Manual:[url=]http://www.sparkfun.com/datasheets/Wireless/Zigbee/XBee-900-Manual.pdf[/url]
  • Dimensional Drawings:[url=]http://www.sparkfun.com/datasheets/Wireless/Zigbee/XBee-Dimensional.pdf[/url]
  • X-CTU:http://www.maxstream.net/support/xctu/setup_x-ctu.exe
不知道兼容FY遥控转接板不?
哪位高手能做一个也不胜感激~~!!!!!!
发表于 2011-3-4 09:35 | 只看该作者
原帖由 bobmaxiao 于 2011-3-4 00:20 发表
应该能吧,我试过ardu和xbee用在一起。
你测试过远距离传输吗?
发表于 2011-3-4 08:44 | 只看该作者
链接我想没有什么问题 TTL 的  不过50MW 可以传送10KM  我觉得有待 买了的同好 试验试验 给个结果
不要到时只可飞个1KM 就没有什么意义了
发表于 2011-3-4 00:20 | 只看该作者
 楼主| 发表于 2011-3-3 13:01 | 只看该作者
Indoor/Urban Range up to 450ft (140m).
Outdoor RF line-of-sight Range
up to 1.8 miles (3 km) w/2.1dB dipole antenna
up to 6 miles (10 km) w/high gain antenna
Transmit Power Output +17 dBm (50 mW)
RF Data Rate 156.25 kbps
Serial Interface Data Rate
(software selectable)
3.3V CMOS Serial UART (5V tolerant UART)
Receiver Sensitivity -100dBm
使用高增益天线能到10km
发表于 2011-3-3 12:53 | 只看该作者
50MW的功率能传10KM?而且还是156K的速率?
发表于 2011-3-3 11:14 | 只看该作者
21AP要是能控制美国的F22就好了:em15: 这当然是开玩笑
理论上讲是完全没有问题的,把XBEE的通信信号转化成TTL信号就没问题了
发表于 2011-3-3 11:09 | 只看该作者
我已经入手一套XBEE ,价格很贵近1300元。
发表于 2011-3-3 10:56 | 只看该作者
哇 确实很诱人
 楼主| 发表于 2011-3-3 09:58 | 只看该作者
21ap能对接这个地面站就更好了。
