查看: 8484|回复: 50
FPV 遥控UHF神器到了,还是选靠谱的,刚开苞图
发表于 2012-9-30 19:27 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
介绍:
The EzUHF transmitter is a true powerhouse with a wealth of connectivity broadening the horizon for each FPV pilot. Headtracking support has now been taken out of the hands of the RC transmitter and is exclusively handled by the EzUHF transmitter, so any radio can be used with your TrackR2 now. Support for any radio battery voltage is guaranteed as well, as the EzUHF transmitter has a power-in jack which will accept a 3S LiPo, so no soldering in your precious RC transmitter is required. For Futaba systems using a 9.6V battery or 3S LiPo the EzUHF transmitter can be powered directly from it, with just a single cable. The battery voltage, either from the external battery, or provided by the radio, obviously is monitored and an audible alarm will sound when the battery gets low.
The EzUHF transmitter comes with an auxilary input that’ll offer exciting upcoming new features for FPV/UAV use. The EzUHF transmitter also comes with a power boost switch, which boosts the power if you happen to put yourself in a tight spot and need to regain control. And we’ve not even touched upon the full duplex capabilities of the EzUHF solution, which is exclusively available on the EzUHF transmitter and the 8-ch EzUHF receiver, turning both into full blown transceivers and hence opening the door for exciting future possibilities.
these clips may work to clip it to your radio handle!
-Reliable FHSS Link (Frequency Hopping, Spread Spectrum)
-433MHz/70cm Ham band operation
-GFSK modulation
-600mW (~28dBm) output power
-Direct head-tracker input, adding head-tracker compatibility to most radios
-Power switch, boost power when at long range
-Standard SMA antenna connector, compatibility with 70cm antennas
-Flexible buffered, AC-coupled, PPM input, ensures compatibility with 3.3v thru 9.6v PPM levels
-Standard USB port (Mini-A) for firmware upgrades, and system configuration
-Single pushbutton learning of failsafe positions
-Binding function, which allows binding Single Tx->Rx, Multi Tx->Rx, and Single Tx->Multi Rx
-Mates with 8 channel, and 4 channel EzUHF receivers
-Power sourced directly from the R/C Tx (Futaba), or optional DC power jack
-Built in receiver, for future expansion
-Custom extruded brushed aluminum enclosure
发表于 2012-10-16 12:33 | 只看该作者
gg
50
发表于 2012-10-16 10:51 | 只看该作者
49
发表于 2012-10-6 17:56 | 只看该作者
你太年轻了。你真的以为有那么多人回复你吗?其实我是看你可怜,于是,我不辞辛劳的注册了很多ID,不断的回复你,希望能满足一下你的虚荣心。但是你要明白,不是所有人都会像我这样为你着想。希望你好自为之。 好了,不说了。我换号继续回复你,不然你不会相信这是真
48
发表于 2012-10-4 20:03 | 只看该作者
太神了。弄个手台可能就被搞死的东西。至于你信不信我是不信了。
47
46
发表于 2012-10-4 13:15 | 只看该作者
神器
45
发表于 2012-10-3 11:28 | 只看该作者
还是UHF厉害,0.5W,就能轻松10公里了,就是价格高了,买不起
44
发表于 2012-10-2 23:05 | 只看该作者
43
发表于 2012-10-2 22:01 | 只看该作者
摆脱你弄个中文说明好不好?
42
发表于 2012-10-2 16:53 | 只看该作者
等待测试报告
41
发表于 2012-10-1 22:39 | 只看该作者
好牛逼的433
发表于 2012-10-1 22:07 | 只看该作者
不知道高科技产品
发表于 2012-10-1 20:32 | 只看该作者
才600mW功率呀,这么小啊。UHF的手台少说都要5W了啊!
发表于 2012-10-1 19:08 | 只看该作者
学习一下
发表于 2012-10-1 17:14 | 只看该作者
是了 我记得也是$300多,$200多把我闪到了。。。
发表于 2012-10-1 16:09 | 只看该作者
淘宝上有一家代购价2800+
发表于 2012-10-1 15:50 | 只看该作者
谁知道这是个啥?
发表于 2012-10-1 13:18 | 只看该作者
发表于 2012-10-1 08:22 | 只看该作者
致以节日的问候,祝大家中秋节快乐!万事如意!
