查看: 44|回复: 1
APC出MR多旋翼系列了,用3108,可升级f550动力吧
发表于 2013-12-26 16:22 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
潜水好久原来13年6月APC就推出了MR系列多旋翼专用桨:
一直觉得APC慢速的虽然质量和平衡都很好,但是颜色难看,形状难看,mr系列桨的样子我很喜欢哈~
然后我又发现了一款新的电机,可能是我out了现在才发现:朗宇的3108
因为一般的盘式电机都是低kv配大桨,一般都是1238以上,erf550轴距有限,最多装10寸桨,但这个电机是盘式高kv:
型号X3108S
定子直径31mm
定子高度8mm
电机Kv900
无负载电流(A/10V)0.9A
电阻86m
最大工作电流25A/30S
最大功率370W
重量81g
外壳直径37.8mm
轴径4mm
轴长26.5mm
整体长度33mm
适用电池节数3-4S
适用螺旋桨型号(inch)APC10x3.8;  APC11x4.7;   APC12x3.8
PropVoltsAmpsThrust(g)RPMWatts (W)Efficiency
(g/W)
Full throttle temperature
(inch)(V)(A)(RPM/Min)
APC103811.11180317011.116.2
2270398522.212.2
3360455033.310.8
4430493744.49.7
5500524555.59.0
6570553766.68.6
7630581177.78.1
8680604288.87.7
9730624099.97.3
1077064281116.9
128606762133.26.5
149407037155.46.0
1610007242177.65.6
1810907457199.85.556°
APC114711.11210268211.118.9
2300334222.213.5
3390377133.311.7
4460411444.410.4
5520438855.59.4
6580462066.68.7
7650487777.78.4
8710503188.88.0
9750519499.97.5
1080053311117.2
128905617133.26.7
149705870155.46.2
1610506100177.65.9
1811306265199.85.7
20120064802225.4
21.912506600243.095.162°
APC123811.11210247711.118.9
2300304222.213.5
3380342033.311.4
4460371144.410.4
5530397755.59.5
6590419066.68.9
7650432877.78.4
8700448288.87.9
9740461199.97.4
1079047401117.1
128804928133.26.6
149605117155.46.2
1610305254177.65.8
1811005365199.85.5
20116055122225.2
2212005625244.24.9
24.812505760275.284.583°
APC103814.81230354814.815.5
2340431129.611.5
3430483444.49.7
4520533159.28.8
56005708748.1
6680597488.87.7
77406240103.67.1
88006480118.46.8
98706668133.26.5
1092068571486.2
1210207217177.65.7
1411207500207.25.4
1612007800236.85.1
1812707997266.44.8
20133081682964.5
2314208460340.44.2
26.815308780396.643.985°
APC114714.81230291414.815.5
2340357529.611.5
3440407144.49.9
4530445159.29.0
56104705748.2
6690497088.87.8
77505228103.67.2
88105400118.46.8
98705588133.26.5
1092057771486.2
1210106034177.65.7
1411106317207.25.4
1611906530236.85.0
1812606720266.44.7
20133069402964.5
2314107140340.44.1
2614907300384.83.9
30.215807500446.963.594°
这样按照表中的数据打个85折,f550就可以配900kv的,1045桨,全重在2600g,用4s 6200mah,保守估计飞行15分钟以上。
早些发现这个我就不用dji的2212了,力道实在不够,大家有什么想说的~
发表于 2014-1-3 10:15 | 只看该作者
我也打算买这款kv900的,可是缺米啊
来自iphone客户端
