查看: 2980|回复: 24
433M高频头,给大家看个好东西
发表于 2014-1-3 17:40 | 只看该作者 |只看大图 回帖奖励 |正序浏览 |阅读模式
OrangeRX Open LRS 433MHz Transmitter 1W ( JR Compatible),好东西啊, 433MHz1w 高平头, 那个将FPV飞到太空的David就是用的这个高频头,技术参数如下:
The all new OrangeRX Open LRS TX Module is an open source transmitter module that can be programmed to use your choice of protocol and any channel in the 400~460MHz range. It is a fully user-customizable RF transmitter system. It can even be programmed to utilize extra features such as telemetry when used with the OrangeRX OpenLRS Rx module.
The OrangeRX Open LRS TX Module a very versatile unit perfect for your custom projects.
It utilizes a 1000mW RF unit and Atmega328 processor with Arduino Bootloader allowing you to upload pre-written codes or write your own to suit your transmitter needs.
The default code utilizes 3 channel frequency hopping. If you would like to use a different protocol, you can write your own hopping codes or simply download one of the many pre-written OpenLRS code sets already available.
Features:
• 3.3v FTDI support for easy programming (DO NOT use 5V serial / AVRISP adapters)
• Serial Port for firmware upload and telemetry application
• I2C port for sensor applications (Wii Motion Plus based Headtracker)
• 16Mhz Atmega328 processor with Arduino Pro Mini compatible bootloader.
• LM2937 3.3v voltage regulator
• U.F.L connector between PCB and antenna
• Buzzer for audible information
• 1000mW output, frequency hopping capability and hundreds of features
Specs:
Compatibility: 5-pin JR compatible module-based transmitters
Frequency: 433MHz
Voltage input: 6.8~12VDC
IC: Atmega328P
Power: 1000mW
Range: Full range system
Includes:
OrangeRx OpenLRS Tx Module (JR compatible)
Antenna
*Note: The setup and use of Open LRS requires computer programming skills and basic Arduino experience. This is not a "plug and play" system. See the attached document under the "Files" tab for resources on programming info, firmware downloads and more.
*Note: Open LRS uses 3.3v FTDI support, DO NOT use a 5V serial / AVRISP adapter or damage will occur.
*Note: Please check with your local authorities regarding the operation of this equipment before you purchase. Regulations on power output, usable frequencies and licenses’ to operate vary from region to region.
本来想买的, 但你妈看到下面那个note:不敢玩啊(红字体), 怕不会玩,开源的高频头还真是第一次听说....唉,水平有限....
发表于 2014-1-4 13:37 | 只看该作者
留意了 呵呵
发表于 2014-1-4 09:48 | 只看该作者
看着挺不错的。
发表于 2014-1-4 09:12 | 只看该作者
怎么换天线
发表于 2014-1-4 06:44 | 只看该作者
北方孤狼 发表于 2014-1-4 00:02
这么便宜,真是个好消息!
再便宜,没技术,买了也是垃圾,呵呵。
qzbzx 发表于 2014-1-3 19:29
最近又是开源飞控,又是开源遥控,再来这个开源高频头。。。。。吃不消啊。。。。。。感觉越开越无知。。 ...
呵呵,玩的无限广......
就怕没技术!
发表于 2014-1-4 00:02 | 只看该作者
加国飞手 发表于 2014-1-3 19:10
开源型的,不然也不会卖31美金这么便宜了......
这么便宜,真是个好消息!
发表于 2014-1-3 22:20 | 只看该作者
IIC串口一应俱全,看着有点心动啊
发表于 2014-1-3 20:54 | 只看该作者
橘子嘛。。。一直都有的
发表于 2014-1-3 20:52 | 只看该作者
新手潜水学习,灌水积分顶帖。
发表于 2014-1-3 19:51 | 只看该作者
好东西啊
 楼主| 发表于 2014-1-3 19:29 | 只看该作者
最近又是开源飞控,又是开源遥控,再来这个开源高频头。。。。。吃不消啊。。。。。。感觉越开越无知。。。。。。。。
发表于 2014-1-3 19:24 | 只看该作者
hobbyking的商品。我充值10美元,点数也没有,有人能帮上忙吗?
发表于 2014-1-3 19:23 | 只看该作者
qzbzx 发表于 2014-1-3 19:15
求链接,阳光哥
http://bbs.5imx.com/bbs/forum.php?mod=viewthread&tid=824258&highlight=433 回复真难......
 楼主| 发表于 2014-1-3 19:15 | 只看该作者
阳光哥 发表于 2014-1-3 19:11
论坛里有人介绍过这个433了,很厉害的样子
求链接,阳光哥
发表于 2014-1-3 19:11 | 只看该作者
 楼主| 发表于 2014-1-3 19:10 | 只看该作者
云淡风轻的云 发表于 2014-1-3 18:57
论坛这么卡啊~~
巨卡, 学习了, 不过不是很懂,能讲的再详细些就好了
发表于 2014-1-3 18:57 | 只看该作者
论坛这么卡啊~~
发表于 2014-1-3 18:56 | 只看该作者
这个才是,设计只能50MW输入,7W输出,所以1w的模块是没戏的,只有100MW的版本程序选择降半输出。
