查看: 3575|回复: 36
有人用过KDS900吗?号称超越GY520的
发表于 2010-4-20 12:33 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Featuresprefix = o ns = "urn:schemas-microsoft-com:office:office"
AVCS system
Since rudder trim changes caused by wind and other meteorological changes and other helicopter attitude changes are automatically cancelled, tail (rudder) operation is easy, making it perfect for 3D flight.
SMM gyro sensor
Use of newly developed extremely low drift SMM (Silicon Micro
Machine) gyro sensor virtually eliminates rudder trim changes
during flight.
Support boardband and narrowband digital servo
You can configue 1520uS servos and 760uS servos via setup card.
Remote gain function and mode switching function
Remote gain function allows sensitivity switching from transmitter, and mode switching function allows AVCS/normal gyro mode switching.
Integrated, compact, and lightweight
Compact size (20 x 20 x 10mm) and light weight (8g) realized by
high density mounting technology.
Set contents
Open the packing of KDS900, below parts are included.
1 pc of KDS900 gyro
1 KDS N590 digital servo
1 setup card
1 sheet double-sided tape
1 manual
KDS900 Specifications
Control system: digital Proportional Integration
Sensor: ADI SMM high functions angular velocity sensor
Working voltage: 4V-6V(DC)
Working current: <55mA
Working temperature: -10-+45
Dimension: 20 X 20 X 10mm
Weight: 8g
Functions:
Servo type options, direction switch, servo left or right travel limit adjusted separately, mid-trim adjusting,
stick sensitivity adjusting, and curve adjusting.
The gyro effect and modes ( AVCS and normal) can be adjusted or switched via transmitter.
KDS N590 servos series brief introduction
The servos are high performance digital servo. They come with coreless motor and special alloy shell, which can send out the heat created when working to ensure the servo can work steadily. The servos adopts high strengt and high tenacity nylon gear. They feature low noise, smooth operating, and provide best operating efficiency. They can work as the swash servos and head lock servo for 500 size and smaller size helicopters.
Parameters:
Model
Speed
Torque
Operating frequency
(Hz)
Dimension
weight
KDS-N590
0.08/60 @4.8V
prefix = st1 ns = "urn:schemas-microsoft-com:office:smarttags" 2.0kg/cm @4.8V
300
35.5mm x 15mm x 28.6mm
25g
发表于 2010-4-20 12:45 | 只看该作者
还不如说超神五呢
发表于 2010-4-20 12:47 | 只看该作者
等待白老鼠。。。:em15: :em15: :em15:
发表于 2010-4-20 12:55 | 只看该作者
晃眼520  :em04:
发表于 2010-4-20 12:56 | 只看该作者
KDS800超越401 KDS900超越520,是郭德纲在说相声么?
发表于 2010-4-20 13:01 | 只看该作者
啊哈哈哈。。。。大家的回复很搞
发表于 2010-4-20 13:44 | 只看该作者
520它表弟:em07:
发表于 2010-4-20 13:52 | 只看该作者
:em17: 不懂英文啊
发表于 2010-4-20 14:28 | 只看该作者
KDS800还是不错的,只是冬天温飘大,第一块电池飞完后才稳定下来。
如果KDS900解决了温飘问题,就很不错了。管它什么401、520的,锁得住就好。
发表于 2010-4-20 14:47 | 只看该作者
谣言吧,头打得这么响,价钱一定不便宜,有点像PG800和BLS251D的感觉
发表于 2010-4-20 14:50 | 只看该作者
:em17: 算了吧....又在忽悠 新手!!的料!!
发表于 2010-4-20 16:17 | 只看该作者
刚在淘宝查过KDS900要700多。。。那价钱不如买401算了。
发表于 2010-4-20 16:27 | 只看该作者
:em16:
发表于 2010-4-20 18:56 | 只看该作者
看不起这种连外形都要仿的行为,没出息!:em09: :em09: :em09:
发表于 2010-4-20 19:19 | 只看该作者
估计都差不多吧
发表于 2010-4-20 20:12 | 只看该作者
期待
发表于 2010-4-20 20:34 | 只看该作者
:em20: 样子很高级嘛
发表于 2010-4-20 22:45 | 只看该作者
连最大角速度都没标……
有个印象,那些大叫“超过Futaba”的,无一例外是噱头。全部都是性能很差的底端产品,最后无一例外都变成一个个大大的失望。真正性能在Futaba之上的品牌根本不用搞这一套。
发表于 2010-4-21 09:42 | 只看该作者
这个陀螺我用过,超小
刚开始拿到的时候无从下手
设置跟GY611差不多
先连接好设置器
然后设置好后拔掉
用的是9257
锁尾钢建得很
发表于 2010-4-21 12:01 | 只看该作者
呵呵,我还是第一次听说这个900。
