楼主: 论坛老模友
国外喷气直升机
发表于 2006-1-15 15:18 | 只看该作者
这个是JETCAT的,网上订购好像合三万多人民币的样子..
型号可能是HP5
Real turbine power with tremendous reserve, capable of powering even the largest helicopters
Rotor direction selectable for either (CW/CCW) rotation
Rotor decoupled from turbine via centrifugal clutch allowing the rotor to stop when the turbine is at idle
Optional servo driven rotor brake
Original JetCat AutoStart system:
Fully automatic turbine startup by a command from the R/C transmitter, without external connections
Low maintenance, quiet running tooth belt drive
in the primary gear stages
Special shaped gear mechanism in the final gear stage for silent operation and positive power transmission
Complete package: unpack, install, fly!
Over 1000 customers have proven the reliability
of this turbine engine power plant.
Precision ceramic ball bearings for low maintenance operation.
Screen in front of the turbine inlet avoids FOD
(foreign object damage) of the compressor / turbine
Special CAD designed turbine wheel, for maximum shaft power at minimum residual thrust
Original JetCat “Jet-tronic” ECU: RPM regulator for constant rotor speed. User programmable electronics.
Turbine starts without compressed air or fans. Automatic cooling when the turbine is shut off.
RS232 serial interface for linking to a computer
Plain text display of the current running parameters for example: exhaust gas temperature, RPM, fuel consumption,
remaining fuel, last run time, total run time, battery voltage,
turbine condition, last shut-down reason, etc.
英文我可翻译不好也没空翻译哈哈....
[ 本帖最后由 cocola 于 2006-1-15 15:19 编辑 ]
发表于 2006-2-15 17:44 | 只看该作者
不错的说
发表于 2006-10-17 18:09 | 只看该作者
:em17: :em17: :em17:
发表于 2006-10-17 19:23 | 只看该作者
一定很贵的,想都不敢想,只能看看了.哈
发表于 2006-10-17 22:19 | 只看该作者
看看还可以,飞的话比宝马费用还高
发表于 2006-10-18 15:54 | 只看该作者
原帖由 正负螺距 于 2006-10-17 22:19 发表
看看还可以,飞的话比宝马费用还高
不是吧,来比比啊:em15:
发表于 2006-10-18 17:15 | 只看该作者
现在还停留在流口水的阶段
发表于 2006-10-18 21:22 | 只看该作者
哇!!!够爆!!!
:em16: :em16: :em16: :em26: :em26:
发表于 2006-10-19 11:46 | 只看该作者
:em26: :em26: :em26:
发表于 2006-10-21 16:17 | 只看该作者
是烧汽油的吧?
发表于 2006-10-27 21:46 | 只看该作者
:em24: :em24:
发表于 2006-11-9 14:18 | 只看该作者
ding  a
发表于 2006-11-9 19:57 | 只看该作者
:em26:
发表于 2006-11-10 13:08 | 只看该作者
厉害啊
发表于 2006-11-11 12:46 | 只看该作者
这个大概要多少钱?????无振动的直机:em21: :em21:
发表于 2006-11-11 17:48 | 只看该作者
漂亮
发表于 2006-11-12 19:54 | 只看该作者
:em19: :em17:
发表于 2006-11-17 09:49 | 只看该作者
一定很贵,不想了
发表于 2006-12-19 15:49 | 只看该作者
看看就行了,没钱买啊
发表于 2007-1-8 18:58 | 只看该作者
#8  #30
航空煤油可比汽油便宜多了。。。。而且涡轴的功率比发动机要高很多,,,虽然他响应慢一点
现在很多大飞机都是涡轴的哦
