楼主: enzozr
MKS DS530 裸体PK 65MG-----------------感谢铁汉在64楼的深度拆解补充
发表于 2010-4-13 11:38 | 只看该作者
5个点脱焊后就取下的,不麻烦!但就怕是普通电机,那就麻烦大了,因为空心杯电机的耐压值范围是比较大的,过流散热也较快,烧毁的可能性也小,就算上到6V也不怕,如果是普通电机的话,就扑410M的后尘。如果真是空心杯电机的话,那就可以彻底超过65MG。实话实说!!!别见怪!!
发表于 2010-4-13 11:43 | 只看该作者
其实65还是不错的,当然要买到正货
 楼主| 发表于 2010-4-13 11:50 | 只看该作者
原帖由 gzbzyj67 于 2010-4-13 11:38 发表
5个点脱焊后就取下的,不麻烦!但就怕是普通电机,那就麻烦大了,因为空心杯电机的耐压值范围是比较大的,过流散热也较快,烧毁的可能性也小,就算上到6V也不怕,如果是普通电机的话,就扑410M的后尘。如果真是空心杯电机的 ...
本人焊接水平超差,焊接T插都不顺手。这5个点脱焊我这舵机肯定玩完:em25:
发表于 2010-4-13 12:16 | 只看该作者
545和530居然不支持Gy401的数码模式!
原帖参见http://www.rcgroups.com/forums/showthread.php?t=1145440
Hello all,
I recently bought some MKS DS530 and DS545 servos for use on my blade 400. these servos will not work in digital mode with the GY520 and GY401 gyros. they must be set to analog when using these servos. My tail servo failed in flight causing an emergency auto (no damage). I wrote MKS and they have been very helpful in the matter and quick to respond. here is their 2nd e-mail to me.
Dear sir Brandon Lenart :
We are sorry not reply earlier, Thanks again for your information, we are appreciate it your notice. In this moments recently got some issue like your side problem,. we have check from our side RD assist, due to probaly we found the GY520 or GY401 have been updgrade soem software insdie, thats why the DS545 can be locked well, please switch the set in: postion on Analog servo 1520/70hz can be work well no problem, thanks. just in case only this 2 servo have suitable problem we find it, hope this can be help & solve it your setup have a fun fly .
Hope this is OK with you. If not, let me know by email ASAP, If there is anything else I can do for you on/regarding this matter, please feel free to contact me at any time. Your prompt attention to this matter will be appreciated. Any comments will be much appreciated. hope hear form your reply soon.
Very respectfully yours.
Best regards
fuhsong Hwang Nov 20,2009 pm17: 30
NO support digital servo setting on this ds545 servo. because the Gyro 401/520 has been updated several software can not keep up too fast ..so thats why its can locked well, please switch the set in: postion on Analog servo 1520/70hz .
1. Change another Gyro , so sorry about this inconvience. if you can.
2. try our ds9670 or 9660 it will handkle it well on 450 Heli class
I hope this prevents any future accidents.
Brandon
号称Gy401和Gy520代码更新太快,MKS研发部门没有跟上进度,所以不支持数码模式。问题是,Gy401都多少年前的产品了,难道545、530比它还老?
发表于 2010-4-13 12:22 | 只看该作者
原帖由 enzozr 于 2010-4-13 09:46 发表
那看来某些商家夸大宣传了·································
348620
据我所知,MKS好像只有35g等级以上的舵机,才有使用镀钛合金,其他齿轮有镀铬合金增加耐磨度
发表于 2010-4-13 12:38 | 只看该作者
做工还不如DS410
发表于 2010-4-13 12:51 | 只看该作者
其实如果410M能更换好点的齿轮也是很不错的:em21:
发表于 2010-4-13 12:52 | 只看该作者
学习了
发表于 2010-4-13 13:00 | 只看该作者
很多厂家乱标参数,得经过严格检测才能得到实际的参数
正在考虑试试MKS的 DS530    工作电压是5V   用在450上面可以直接用吗   会不会烧掉噢?:em22:
发表于 2010-4-13 13:40 | 只看该作者
545和530居然不支持Gy401?:em20:
发表于 2010-4-13 13:55 | 只看该作者
终于有人拆530啦:em15:
支持LZ
最近212的升级版313也出来了
同样希望LZ能上拆机图看看
还有5个完整65待我炸,530相当吸引人啊 :em07:
看起来不像是空心杯电机,而且,个人比较鄙视这种焊装方式,不好换电机。不是每个人焊接水平都高的。
发表于 2010-4-13 14:09 | 只看该作者
这种测试只有老羊才专业
发表于 2010-4-13 14:10 | 只看该作者
其它人不是托就是托
 楼主| 发表于 2010-4-13 14:17 | 只看该作者
回复 35楼 xianglei6619 的帖子
荣幸啊,我也成托了:em15:
 楼主| 发表于 2010-4-13 14:22 | 只看该作者
530拆解告一段路,下面拆8910
发表于 2010-4-13 14:28 | 只看该作者
更正一下
DS530 = DC 電刷馬達
DS545 = 空心杯
可能MKS想表達的數據太多,反而寫的很亂,記不清楚
 楼主| 发表于 2010-4-13 14:29 | 只看该作者
老羊是本论坛开创拆机全面对比的前辈,大家都像他学习才能提高交流水平
俺水平有限,只能拆到这个份上,大家将就看看吧:em15:
发表于 2010-4-13 14:35 | 只看该作者
铁汉来更正了。。。
裸体不够彻底,我们需要正面全裸:em15:
