afcekyk3057,你好,我是上海的.这样的飞机我也是第一次装,是不是好飞我心里也没底,因为上海这里这几天比较冷,周围也没有大一点的场地,再说我得飞行技术也不过关,什么时候放襟翼,放多少,怎么拉空气刹车等问题还没搞清楚.所以目前还不敢冒然试飞.不知你的飞机到什么程度了,怎么装的,怎么设置的,有没有飞过.有好经验的话一定要分享一下.
22楼的模友,你好,慢放起落架的设置如下:
1.设主通道为第3通道,跟随通道也为第3通道,两边行程均为-100%,不设控制开关.(这一步关闭了第3通道的默认功能)
2.设主通道为第3通道,跟随通道为辅助通道(我设的是第5通道),link关,trim关,控制类型为油门杆,行程两边都为+100%.(第3通道功能放在第5通道上)
3.设offset为主通道,第3通道跟随,设定某个开关为控制开关(如G开关),向上+100%
4.设offset为主通道,第3通道跟随,设定这个开关为控制开关,向下-100%
(第3,4步将第3通道改由某个开关控制,如起落架开关G)
最后还需在Throttle Delay 界面里设延时时间.
以下是Futaba网站的原文:
For the first mix, you will go into the advanced menu and create a mix from Throttle to Throttle at -100% each way with any switch in the Null position, this will turn off the throttle stick action for you.
Second mix, you will want to make Throttle master and Aux2 as slave, Link Off, Trim Off, the switch should be set to STK-THR and the rates should be +100% in both directions.
Next you will want to make another mix with Offset as master, and Throttle as Slave, for this example you can put this on Switch C in the UP position at +100%.
For fourth and last mix, again do an offset mix with Offset as Master and Throttle as Slave and then put this on Switch C in the Down position at -100%.
Lastly all you need to do is go into Throttle Delay and set the amount of delay you want on this servo. |
