楼主: 似水流年
过节啦,上个JJ大家看看
 楼主| 发表于 2012-6-21 22:33 | 只看该作者
主轴转速切换手柄及冷却液喷头
主轴转速切换手柄及冷却液喷头
 楼主| 发表于 2012-6-21 22:36 | 只看该作者
美中不足,台面大大小小好几个坑,还好台面总体平整
 楼主| 发表于 2012-6-21 22:38 | 只看该作者
140MM直径的立柱
140MM直径的立柱
发表于 2012-6-21 22:41 | 只看该作者
上楼了吗?
 楼主| 发表于 2012-6-21 22:49 | 只看该作者
当然啦,几年前的事啦,有哪位大师了解这台JJ?以下可以看到这台JJ一个很大的优点就是可以分解成简单的几部分,这对于搬运上楼是很重要的
[ 本帖最后由 似水流年 于 2012-6-21 23:01 编辑 ]
发表于 2012-6-21 23:46 | 只看该作者
瑞士的机机,老货:em15:
发表于 2012-6-22 00:08 | 只看该作者
原帖由 liuyan 于 2012-6-21 23:46 发表
瑞士的机机,老货:em15:
老大呀
sweden是北歐的瑞典,不是中歐的瑞士啦
老貨肯定是很老的
Arboga Maskiner的鑽床算是世界知名的
尤其是旋臂鑽,可以排上前三名
早期高雄拆船業發達時
時常可以在公園路上看到這個牌子的超大鑽床
看了一下結構
這台應該還是歸類為鑽床一族
主軸應該是莫氏三號柄的
機頭沒拉桿
夾頭會非常容易掉下來
當銑床會不太好用
 楼主| 发表于 2012-6-22 09:04 | 只看该作者
决定入手前查了些资料
决定入手前查了些资料,全是英语,水平有限只能知道大概,这方面港台同胞极具优势,如能帮忙翻译我和坛友将不胜感谢
文字资料1
AB Arboga Mekaniska Verkstad of Sweden have made, over the years a wide range of products: power shears, press brakes, eccentric presses, chip crushers, straightening machines, wire-drawing machines tube draw benches, small and miniature milling machines and a very wide range of drills. Their popular EM825 (and later very similar U2508) mill/drill was a well-made and versatile machine with a geared-head based on the company's similar range of small drills and co-ordinate and radial-arm drilling machines. The machine appears to have superseded two earlier version, the E135, fitted with a single-speed motor and a 100 to -640 r.p.m. speed range and the next version, the very similar-looking 2-speed motor E830 with speeds from 80 to 890 r.p.m. Whilst the early models are rare the EM825 was heavily promoted and sold well in both European and North American markets from the 1950s to late 1970s.
Raised and lowered by a crank-operated rack-and-worm mechanism (fitted at the back of the 4"(101.6mm) diameter column) the swivelling head was equipped with both fine down-feed and a rapid-action drilling quill with 41/2"(114.3mm) of travel. To keep the head in alignment during vertical movements the rack was ground on both edges and let into the column, an adjustable gib strip being provided to take up any lateral play that might develop during service. From the centre of the spindle to the column was 107/16"(265.1mm) and the maximum distance from the spindle face to the table 12"(304.8mm). The micrometer dials were fitted with vernier graduations to 1/500"(0.051mm).
Either a two-speed 3-phase, or 1-phase 1400/2800 rpm motor could be specified to drive the 8-speed geared head at speeds of 100, 150, 205, 300, 440, 640, 880, and 1280 rpm. At 2800 r.p.m. the 3-phase motor was rated at 0.9 h.p. and 0.6 h.p. at 1400 r.p.m. A high-speed option was also listed, with the choice of two speed ranges:
a) 100, 205, 250, 440, 510, 885, 1040 and 2080 r.p.m.
b) 100, 205, 345, 440, 695, 885, 1450 and 2900 r.p.m.
Various sizes of table were available, but the one most commonly found has a working surface of approximately 17.3"(439.42mm) x 9.43"(239.52mm) with 11"(279.4mm) inches of longitudinal movement and 6.5"(165.1mm) of cross travel. Most seem to have been fitted with ball thrust races on the feed screws and some with ball races where the shaft passed through the of the casting. An oil-immersed, power-feed gearbox was an option but, being very expensive, is rarely found.
Very heavily built, the head, once tilted over, could be difficult for one person to hold whilst the retaining nut was tightened. Although the vertical position was held by a locating taper pin, once outside this setting the head was secured by friction alone and on a limited surface area. However, experienced long-term owners report that this is not a problem and that even under heavy cuts the rigidity of the head is not compromised. At some point in the late 1960s it appears that the original EM825 was superseded by an interim model, a
heavier version with the larger column and table that appeared on the next generation of Arboga millers, the U2508 (the latter also being built as a copy in Taiwan during the 1970s and 1980s).
There are one or two details about the spindle that are worth knowing: it was fitted, as standard, with a 3-Morse taper, with a tang knockout but, because the spindle line was blocked by the motor above, without a draw-bar for holding cutters in the head; instead, a screwed ring on the spindle nose retained a "slotted" washer which was slipped over the neck of a cutter between its Morse taper shank and the cutting edges. Only one "washer", distance piece and retaining ring were required for the full-size 3-Morse fitting, but to hold tapers of
No. 2 and 1-Morse in adapter sleeves (and the special drill chuck) a total of five were needed. These items are still available, but very expensive, the parts for the 3 Morse holder alone costing over
£240 in 1999. In addition, before a standard "Autolock" chuck can be used in the head, it needs to be modified to accept the retaining ring and plate; this is, however, an apparently simple matter. If you are going to buy an Arboga, check that the cutter-retaining parts are with the machine, or budget accordingly to buy them.
Unaccountably (unless they are, perhaps, Russian copies) some machines have their head assemblies made from "mirror-image" casting; this, of course, has the effect of putting the gear levers on the right-hand side and the quill-feed controls on the left.
Copied by the New Bharat Engineering Works of Pandit Nehru Road, Jamnagar 361-002, India, the EM825 was also sold as the "VM-25 Energy". This model was mounted on a compact cabinet stand, similar to the original, but with a coolant pump and tank enclosed within the base and a neat, facia-mounted electrical control panel. The Modig company of Virserum, Sweden, also manufactured a very similar geared-head mill-drill, the UM3508
Fitted to its maker's stand the Arboga EM825 weighed,
approximately 530 lbs.
Another interesting Arboga product was the beautifully-built, ingenious
but rarely-seen UM400, a miniature combination machine..
Rare table power-feed gearbox. Note the sight-glass oil level window
[ 本帖最后由 似水流年 于 2012-6-22 09:30 编辑 ]
 楼主| 发表于 2012-6-22 09:07 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:08 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:10 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:11 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:16 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:17 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:18 | 只看该作者
资料照片
资料照片
资料照片
 楼主| 发表于 2012-6-22 09:24 | 只看该作者
文字资料2
a.The basic U2508 on the maker's rather narrow cabinet stand
b.Although the castings of the U2508 were 'squared-off' and the vertical column more massive, there is still no mistaking the early-1950s origins of its ancestor machine the EM825.
c.Some examples had full-circle handwheels on the table feed screws, others the more traditional balanced-ball type. This miller is fitted with the maker's table vice.
e.The optional, self-contained, electrically-driven table power feed unit reduced maximum travel by 1" but provided 6 feed rates of 0.75, 1.375, 2.5, 3.75, 7 and 12.5 inches per minute (19, 36, 63, 96, 179 and 315 mm/min). The drive was taken through a safety friction clutch and the motor could be reversed to provided travel in both directions.
f.Of neater appearance than the earlier power feed gearbox, the 6-speed unit fitted to the U2508 incorporated a large angled-face satin-chrome finished micrometer dial.
 楼主| 发表于 2012-6-22 09:25 | 只看该作者
文字资料3
Of identical layout to the early-1950s designed Arboga EM 825, the U2508 was a heavier and generally more robust machine introduced during the 1970s. The distance from spindle centre line to inner face of the column was actually 3/8" less than the EM825 - but this was compensated for by a maximum table to spindle nose capacity of 20", a massive increase of 8" on the older machine. The quill movement was lengthened by 1/2" to 41/2", the main column diameter increased from 4" to 51/2" and the standard table increased from 175/16" x 97/16" to 22" x 10". Although the cross travel remained unchanged at 61/2" the longitudinal travel was increased by 41/2" to 151/2" . An optional, self-contained, electrically-driven table power feed unit reduced maximum travel by 1" but provided 6 feed rates of 0.75, 1.375, 2.5, 3.75, 7 and 12.5 inches per minute (19, 36, 63, 96, 179 and 315 mm/min).
A 2-speed 1/0.85 hp 3-phase motor was standard and drove the No. 3 Morse taper spindle at: 100, 205, 345, 440, 695, 885, 1450 and 2900 rpm - a wonderfully wide range and a considerable improvement on the original 100 to 1280 rpm range.
The all-up weight was 605 lbs.
During the 1970s and 1980s a copy of the U2508 was built in Taiwan.
[ 本帖最后由 似水流年 于 2012-6-22 09:31 编辑 ]
 楼主| 发表于 2012-6-22 09:28 | 只看该作者
文字资料4
SOLD: ARBOGA U2508 Vertical Milling and Co-ordinate Drilling Machine. This is the late-type, all-geared-head Arboga made during the 1970s and 1980s with a heavier construction, greater capacity and more modern lines than the original type. Table 22" x 10". The head has both a worm-gear driven fine feed and a quick-action drilling lever. A very wide speed range is available from 100 to 2900 r.p.m. Complete with maker's stand, collet chuck, machine vice and light unit. In remarkably good original condition: it has had little used from new and is still in the maker's original paint finish. 3-phase electrics and so ideal for the fitting of a low-cost variable-speed inverter drive.
发表于 2012-6-22 09:33 | 只看该作者
圆形立柱我有点担心..担心机头会晃..这个用钨钢铣刀的时候很重要...如果机头晃...无疑是让钨钢刀进fen墓
 楼主| 发表于 2012-6-22 09:40 | 只看该作者
资料照片
资料照片
资料照片
