楼主: neosunrise
悲催的飞越450
 楼主| 发表于 2013-2-12 08:47 | 只看该作者
showdow 发表于 2013-2-11 19:33
斜盘舵机的齿米国不太好买吧-。-
机子慢慢装,精度不好的地方换YT的就好了-。-
我之前买了一堆副厂三轴, ...
请问精度主要是那些部位不行呢?
发表于 2013-2-12 08:50 | 只看该作者
showdow 发表于 2013-2-12 08:33
斜盘舵机的齿米国不太好买吧-。-
我之前买了一堆副厂三轴, ...
国外很多发烧友都是买副厂的空机然后关键件换亚拓。450亚拓兼容机的普遍质量还是不行,当然质量和价格都有高有低。我看到HobbyKing的450空机(兼容亚拓)只有三十多美元出头,都有点动心买一台做静态了,就是家里实在没地方。。。
发表于 2013-2-12 08:54 | 只看该作者
neosunrise 发表于 2013-2-12 08:47
请问精度主要是那些部位不行呢?
每个人经历都不太一样,常换的有旋翼头上的部件(主轴,feathering shaft),尾管,尾桨驱动。
转个老外的评价:Clone kits seem to be hit or miss, Ive heard one guy say great things about his clone kit (ie: Tarot, Chaos, ALZRC, EXI, HK etc) and another guy who got the same kit from the same source had to replace/upgrade several parts. I got the Tarot 450 Pro "Value" kit and was not pleased with the quality at all, ended up replacing/upgrading lots of parts so I would have been better of with an Align kit. Personally unless I'm building a complete beater I won't ever buy a clone again, you can get an Align bear bones kit at really good prices nowadays and get top of the line or budget electronics, the choice is yours and that's the beauty of bear bones kits. Ive actually seen some pretty good deals on Super Combos if your OK with Align electronics and just want to get everything at once or you could sell the electronics and get what you want. In my opinion you would be much better of with a name brand kit especially in the long run, just my 2 cents.
 楼主| 发表于 2013-2-12 08:55 | 只看该作者
coldfire 发表于 2013-2-11 19:50
国外很多发烧友都是买副厂的空机然后关键件换亚拓。450亚拓兼容机的普遍质量还是不行,当然质量和价格都有 ...
我想飞越应该是所有亚拓山寨机当中精度最高的了吧?与亚拓有差距也是自然的,因为与亚拓最起码有100美元的差价。这100美元可以用来做其他的事情了。你说的那个30美元的是啥?
发表于 2013-2-12 08:56 | 只看该作者
这东西说到底自己感觉好就行,不玩hard 3d的话觉得没啥必要抠得太细
发表于 2013-2-12 08:58 | 只看该作者
neosunrise 发表于 2013-2-12 08:55
我想飞越应该是所有亚拓山寨机当中精度最高的了吧?与亚拓有差距也是自然的,因为与亚拓最起码有100美元的 ...
网上找HK450GT,希望TM的不要被当成发小广告的被封掉。。。
发表于 2013-2-12 08:59 | 只看该作者
飞跃的确算是评价比较好的了
 楼主| 发表于 2013-2-12 08:59 | 只看该作者
转个老外 ...
helifreak上网友对Tarot评价还是很不错的,有人说感觉不出来跟Align的差距。不过话又说回来了,我这次遇到的问题就是个典型的跟这个哥们有点像“another guy who got the same kit from the same source had to replace/upgrade several parts.” 可能是品控的确不好的缘故吧,有的出厂之后不错,有的就只能用次品来形容,拼人品了。不过幸运地是ClubHeli的服务态度还不错,只要新机没有问题,我想精度应该对我影响不大。以后真要想做hard 3d,换亚拓的配件就是了。
发表于 2013-2-12 09:09 | 只看该作者
换了的话 还曝光  有点点..
发表于 2013-2-12 09:18 | 只看该作者
个人感觉,仅就此事而言,还是比较公平的。同样一台空机,楼主在万恶的资本主义国家花掉135美元(大概合850元),在天C购买需要680元。这两个价格都是最终售价,所以其中共同存在的税费利润等等成本就不讨论了,那么这170元除了运费,就应该是售后服务的费用了。如果楼主得不到这样的售后服务那才叫悲催呢
 楼主| 发表于 2013-2-12 09:22 | 只看该作者
teana 发表于 2013-2-11 20:18
个人感觉,仅就此事而言,还是比较公平的。同样一台空机,楼主在万恶的资本主义国家花掉135美元(大概合850 ...
说的有道理,跟地平线的产品价格贵是一样的道理。
 楼主| 发表于 2013-2-12 09:23 | 只看该作者
辽宁大山 发表于 2013-2-11 20:09
换了的话 还曝光  有点点..
换了也不能掩盖飞越品控的问题啊
发表于 2013-2-12 09:31 | 只看该作者
发表于 2013-2-12 09:34 | 只看该作者
期待国产的精品,一个好的品牌口碑不仅是好的服务还有好的品质。期待飞跃。飞跃的产品以前还是不错的,现在的新出的怎么感觉越来越离谱了,彩色的各种配件,好像90年代的国产收录机装上10个喇叭600w,1000w的虚标功率没有什么意思。希望厂家能够狠抓产品本质。
发表于 2013-2-12 09:41 | 只看该作者
neosunrise 发表于 2013-2-12 08:59
helifreak上网友对Tarot评价还是很不错的,有人说感觉不出来跟Align的差距。不过话又说回来了,我这次遇到 ...
就是这个道理,要是飞飞航线我觉着应该大家都区别不大,个别的可能装配的时候费点事,或者换个个别零件。玩hard 3d就考验精度和材料强度了,至于摔机就是考验材料强度的真正时刻了。
 楼主| 发表于 2013-2-12 09:44 | 只看该作者
dreamsophia 发表于 2013-2-11 20:34
期待国产的精品,一个好的品牌口碑不仅是好的服务还有好的品质。期待飞跃。飞跃的产品以前还是不错的,现在 ...
是啊,东西变得越来越花哨,但是内在的品质却没有提上去,真是拣了芝麻丢了西瓜啊。
 楼主| 发表于 2013-2-12 09:46 | 只看该作者
coldfire 发表于 2013-2-11 20:41
就是这个道理,要是飞飞航线我觉着应该大家都区别不大,个别的可能装配的时候费点事,或者换个个别零件。 ...
恩恩,其实这次换机也算因祸得福,因为我喜欢银色的,当时买了黑色的就后悔了。所以就着这次机会正好换个银色版的,我感觉比黑色的亮骚多了。另外,亚拓是不是也有不同颜色可以选择呢?
发表于 2013-2-12 09:47 | 只看该作者
厂家要赚钱啊,现在竞争又这么激烈。品牌口碑需要较长的时间建立,没有一定的家底拼不起。还是短平快来钱快,卖一台算一台呗。
很多人觉得既然选择副厂了,那就捡便宜的来吧,所以一众价廉质不优的产品才有藏身之处
发表于 2013-2-12 09:49 | 只看该作者
哦了
发表于 2013-2-12 09:50 | 只看该作者
neosunrise 发表于 2013-2-12 09:46
恩恩,其实这次换机也算因祸得福,因为我喜欢银色的,当时买了黑色的就后悔了。所以就着这次机会正好换个 ...
看亚拓配件里有颜色可选的,没买过亚拓整机,不太了解
