楼主: kevin401
德国Minicopter大菠萝-S竞赛机
发表于 2013-8-8 18:13 | 只看该作者
很帅 但更喜欢 他裸着的样子
发表于 2013-8-8 22:11 | 只看该作者
坑定很贵!
发表于 2013-8-9 01:18 | 只看该作者
好机
发表于 2013-8-13 02:49 | 只看该作者
有点怪异
发表于 2013-8-13 12:21 | 只看该作者
头罩固定用的是香蕉插头么?
 楼主| 发表于 2013-8-13 16:20 | 只看该作者
The superfast Diabolo
The Diabolo-S is a pure high speed model without compromise.  Because  high speed pilots are rare there will be a limited production of 50 helicopters, with ongoing support thereafter.
Aerodynamics and a minimized cutting area similar to Formula 1 cars was the center of development and engineering for the Diabolo-S.
The Diabolo-S is the most extreme speed helicopter available today with its very narrow fuselage and efficient aerodynamics. The nose is extremely aggressive and the complete fuselage is shaped like a knife,  minimizing air resistance like an airfoil for tilting flight angles of up to 20 degrees.  An angled rotor in relation to fuselage center line significantly improves the starting, landing and hovering characteristics of the helicopter.  The Diabolo S was designed for FAI style speed flight over the 200 m distance where perfect aerodynamic besides a perfect flight curve is most important.  The Diabolo-S is extremely narrow and not all ancillary components available on market will fit in the fuselage. The standard Diabolo mechanics is used in the Diabolo-S with CF frames and other component modifications which are included in each kit. To insure mechanical integrity of speed flight the spindle was enlarged to 10mm and the blade grips and bearings were enlarged in the same way.
德國制造
 楼主| 发表于 2013-8-13 16:24 | 只看该作者
德国Minicopter大菠萝-S竞赛机視頻
Diabolo S IRCHA Speed Cup 2013 Final test run
发表于 2013-8-13 17:11 | 只看该作者
可能我土鳖了..............
但是真的很难看
发表于 2013-8-14 19:32 | 只看该作者
香蕉头固定的头罩···
还有电机上的小风扇
还有钢丝脚架
骚死了
发表于 2013-8-17 20:47 | 只看该作者
牛机
发表于 2013-8-27 12:01 | 只看该作者
路过帮顶
发表于 2013-8-28 15:28 | 只看该作者
这飞机很差  单项打滑  温度过高 没地方散热 融齿 等
发表于 2013-8-28 15:30 | 只看该作者
大开眼界
发表于 2013-8-28 17:03 | 只看该作者
這机很有型格。正点
发表于 2013-11-13 09:49 | 只看该作者
设计真是不一般
发表于 2013-11-13 19:29 | 只看该作者
骚货啊
发表于 2013-11-16 14:05 | 只看该作者
真【漂亮
发表于 2013-11-16 21:37 | 只看该作者
還以為是FBL80一類的......路過~
发表于 2013-11-18 22:30 | 只看该作者
tdr更好看,但这个看起来在追求速度的台阶上更上一步,个性的暴力了点。
发表于 2013-11-21 20:34 | 只看该作者
学习一下
