蒸汽和斯特林:发动机
以前发的无法解压,这一本是可正常解压的版本:
William C. Fitt, "Steam and Stirling: Engines You Can Build"
Wildwood Publications | 1980 | ISBN: 0914104063 | 160 pages | PDF | 57,6 MB
At no time in history has participation in metal-working as a hobby grown as fast in America as it has in the past fifteen years. It is a safe assumption that as many metal-turning lathes have been purchased in the past five years for home workshops as were in such use prior to that time. Because of that growth, the need for "how-to" information has increased and Steam and Stirling-Engines You Can Build provides some of those details.
During this fifteen-year period, LIVE STEAM Magazine has been providing Amateur Machinists with projects of varying degrees of complexity but, as The Hobby grew and The Magazine's circulation increased, most of the earlier copies were no longer available. To close this information gap, several of those out-of-print projects are included in this volume so that the many newcomers to the Live Steam Hobby can have available the instruction and design information that they need.
Knowing that only time will produce a home workshop scrap bin filled with the little odds and ends of materials needed to build these engines, arrangements have been made to have all the materials required for the projects in this book to be supplied in kit form. In this way, all those newly-purchased lathes (and many of the existing ones that are being dusted off and put back into use) can be put to work by their owners to make more than a few elementary metal turnings and some experimental threaded rods!
So here is the beginning ... the thrill of building something that actually works is yours by just following the directions. If you are a complete novice in this field, pick one of the simpler projects for your first attempt and gradually work your way through the others as your skill and abilities (and confidence) increase.
The Hobby is enjoyed by persons in all walks of life and we are sure that you will find many pleasurable hours in your workshop with the projects in this book.
William C. Fitt
将英语译成中文 显示拼音
在任何历史时期,在金属参与的速度增长,在美国工作的一种业余爱好,因为它在过去15年来。这是一个安全的假设,即尽可能多金属车削车床已在过去5年的家庭购买了讲习班在这种使用是在此之前的时间。由于这种增长的需要“如何做”的信息有所增加,蒸汽和斯特林发动机可以构建提供的一些细节。
在这15年期间,现场蒸汽杂志提供了不同复杂程度的项目业余机械师,但作为成长的爱好和该杂志的发行量增加,早期的副本大部分不再可用。若要关闭这一信息差距,这些的了几次,印刷工程已列入本书,使蒸汽的活的爱好有很多新人可以提供指导和设计资料,他们的需要。
知道,只有时间才能生产车间废料家庭与小本的赔率和需要建立这些发动机材料填充完,已作出安排将所有在这是在套书的形式提供工程所需的材料。这样,所有这些新购入的车床(和许多正在尘埃,并重新投入使用现有的)可以提出由他们的所有者努力使超过几个基本金属转弯和一些实验螺纹杆更多!
所以,这里是开始...建设工程的事,其实是你的快感只由以下的指示。如果你是在这一领域完全陌生,挑选你的第一个尝试简单的项目之一,并逐步通过您的工作技能和能力(和信心,其他的路)的增加。
享有的爱好是由各界人士和我们确信,你会发现你在与本书中的许多项目研讨会愉快小时。
威廉C菲茨
Download
depositfiles.com
uploading.com
上传者有很多很好的金工和模型发动机杂志(约>10GB)前些时候转发了一部分,但发现无法解压. |
