少在那儿恶心人了 :em08: .
自己终于知道2mm 精度不是火星人那里买来的了八
2mm是做静态 动态1ppm (约2cm)
Carrier phase tracking (surveying)
Utilizing the navigation message to measure pseudorange has been discussed. Another method that is used in GPS surveying applications is carrier phase tracking. The period of the carrier frequency times the speed of light gives the wave length, which is about 0.19 meters for the L1 carrier. With a 1% of wave length accuracy in detecting the leading edge, this component of pseudorange error might be as low as 2 millimeters. This compares to 3 meters for the C/A code and 0.3 meters for the P code.
However, this 2 millimeter accuracy requires measuring the total phase, that is the total number of wave lengths plus the fractional wavelength. This requires specially equipped receivers. This method has many applications in the field of surveying.
我用这样的GPS好几年了,现在价格已经跌的很多了。用载波相位技术的GPS 最低 2-3k 也有了
GPS 速度不能超过2马赫(美国政府限制) 我们进口如果要高hz数的定位输出还要专门定购授权。(现在能得到50hz,授权非常贵,一般10hz较多)
[ 本帖最后由 NeoLu 于 2009-6-26 11:40 编辑 ] |
