- -!800级啊,刚刚查了一下参数这个真不小,19800还是空机,这个要飞起来要多少钱?参数如下: - Overall length(长度): 1,623 mm
- Overall height(高度): 704 mm
- Overall width (宽度): 380 mm
- Gross weight(起飞重量): 7,800 g~ (including main rotor blades JRC800)
- Main rotor diameter(主桨直径): 1,765 mm (w/JRC800)
- Tail rotor diameter(尾桨直径): 288 mm
- Gear ratio(齿轮比): 8 : 1 : 5.18
- Swash(十字盘类型): 120 CCPM (MPM is also available as an option)
