你了解的信息滞后,第一批的确有问题,搭配某些型号摄像头有问题,暂停供货,现在销售的算是第二版。
官方文档中有提起,可以去官网查阅。
Difference Between Batches
As with any product that ImmersionRC has ever made, we strive to improve it between production batches. rapidFIRE is no exception, and we continue to push the limits.Batch 1
Initial batch, met all published specs, but struggled with certain cameras and OSDs which generated mal-formed PAL/NTSC signals. Batch 2
Slightly better sensitivity, and tolerance for cameras and OSDs that Batch 1 had issues with.
Batch 2 can be identified by an additional foam block placed between the antenna connectors.
This protects the screen during the production process.
Batch 2 modules reduced a bit the color oversaturation in RF Mode #1.
第二批在天线插座中有泡沫垫保护屏幕,识别度很高,而且在RF Mode #1中略微减少了颜色过饱和。
![](http://photo.5imxbbs.com/forum/201811/23/110945gzf7e9a6nb8f6xob.jpg)
