突然发现现有的HS 5245MG的指标也不比9650差啊
Operating Voltage: 4.8-6.0 Volts
Operating Temperature Range: -20 to +60 Degree C
Operating Speed (4.8V): 0.15sec/60° at no load
Operating Speed (6.0V): 0.12sec/60° at no load
Stall Torque (4.8V): 61 oz/in. (4.4kg.cm)
Stall Torque (6.0V): 76 oz/in. (5.5kg.cm)
Operating Angle: 45 Deg. one side pulse traveling 450usec
360 Modifiable: Yes
Direction: Clockwise/Pulse Traveling 1500 to 1900usec
Current Drain (4.8V): 3mA/idle and 180mA no load operating
Current Drain (6.0V): 3mA/idle and 230mA no load operating
Dead Band Width: 1usec
Motor Type: 3 Pole Ferrite
Potentiometer Drive: Direct Drive
Bearing Type: Dual Ball Bearing
Gear Type: 4 Metal Gears, 1 Resin Gear
Connector Wire Length: 11.81" (300mm)
Dimensions: 1.3" x 0.7"x 1.2" (32 x 17 x 31mm)
Weight: 1.12oz (32g)
老大能不能测试一下v-bar用5245的性能? |
