Convincing arguments: quality, efficiency and price
Precision-manufactured
Concentricity precision - lathe chuck smaller than 0.05 mm
Concentricity precision - spindle nose smaller than 0.009 mm
With saddle slide, compound slide and cross slide
Automatic longitudinal/leadscrew drive
Hardened work spindle with 2 adjustable taper roller bearings
Taper roller bearings in P5 quality
Rolled trapezoid spindle
Thrust bearing
Leadscrew run on two porous bearings
Leadscrew for threading or automatic longitudinal feed
Massive, matured prismatic bed may of grey cast iron, matured at least for six months inductively hardened (HRC 42-52) and precision-ground
User-friendly automatic off-switch according to IP 54 with low-voltage release, EMERGENCY-STOP button and right-handed/left-handed rotation
quantum D 250 “Vario” type with frequency converter, thus with extreme engine power and almost constant course of torque
High-grade lathe chuck protection
Manufactured according to DIN 8606 (toolmaker’s precision)
High value stability
Extent of supply:
3-jaw chuck Ø 100 mm (D210)
3-jaw chuck Ø 125 mm (D250)
Fixed centre MT2
Fixed centre MT3
Lathe chuck protection
Lathe dog
HSS cutting tools
Rear splash guard
Chip pan
Quadruple tool holder
Operating tools
Change gear kit 10 pcs. from 0.4 to 3 mm and inch-based (10-44 TPI) thread
Test certificate
