楼主: scaple
UAV 地面站软件开发平台 CSS (LZ从火星滚回来了!!!!!409楼)
发表于 2013-11-5 00:04 | 只看该作者
点击查看详情
感谢楼主大神的帮助。我截获了一些自驾中的参数,但是还发现几个问题:
1:好像这22#消息格式和MAVLINK 那个百度文库里《MAVLink通讯协议全文》中的字段排列格式不一样啊。文档中是:
param_id[16字节], param_value[4字节],param_type[1字节],param_count[2字节],param_index[2字节]
但我收到的数据却是
FE 19 D6 01 01 16   , 00 00 00 40  , E8 00, BD 00 ,53 52 30 5F 52 43 5F 43 48 41 4E 00 00 00 00 00, 04 ,99 FC
貌似是param_value[4字节],param_count[2字节],],param_index[2字节],param_id[16字节], param_type[1字节],
但最后一字节貌似和那个TYPE表还是对不上,参数值的数据格式也猜不出来,还盼大虾进一步帮忙啊
附:我截获的一组数据。大虾能把解析结果告诉我吗?万分感谢了:
FE 19 05 01 01 16 00 00 50 41 E8 00 00 00 46 4F 52 4D 41 54 5F 56 45 52 53 49 4F 4E 00 00 04 30 FF
FE 19 06 01 01 16 00 00 00 00 E8 00 01 00 53 59 53 49 44 5F 53 57 5F 54 59 50 45 00 00 00 02 AD DB
FE 19 09 01 01 16 00 00 80 3F E8 00 02 00 53 59 53 49 44 5F 54 48 49 53 4D 41 56 00 00 00 04 D7 79
FE 19 0A 01 01 16 00 00 7F 43 E8 00 03 00 53 59 53 49 44 5F 4D 59 47 43 53 00 00 00 00 00 04 68 7F
FE 19 0B 01 01 16 00 00 E6 42 E8 00 04 00 53 45 52 49 41 4C 33 5F 42 41 55 44 00 00 00 00 02 A2 FF
FE 19 0C 01 01 16 CD CC 4C 3E E8 00 05 00 4B 46 46 5F 50 54 43 48 43 4F 4D 50 00 00 00 CD 09 6D 66
FE 19 0D 01 01 16 00 00 00 3F E8 00 06 00 4B 46 46 5F 52 44 44 52 4D 49 58 00 00 00 00 00 09 EA B6
FE 19 0E 01 01 16 00 00 00 00 E8 00 07 00 4B 46 46 5F 50 54 43 48 32 54 48 52 00 00 00 00 09 8B 82
FE 19 0F 01 01 16 00 00 00 00 E8 00 08 00 4B 46 46 5F 54 48 52 32 50 54 43 48 00 00 00 00 09 26 71 21 47
FE 19 10 01 01 16 00 00 80 3F E8 00 09 00 4D 41 4E 55 41 4C 5F 4C 45 56 45 4C 00 00 00 00 02 8C 4B
FE 19 11 01 01 16 00 00 00 00 E8 00 0A 00 6C 61 6E 64 5F 70 69 74 63 68 5F 63 64 00 00 00 04 86 23
FE 19 12 01 01 16 00 00 C8 42 E8 00 0B 00 58 54 52 4B 5F 47 41 49 4E 5F 53 43 00 00 00 00 09 D3 6E
FE 19 13 01 01 16 00 80 3B 45 E8 00 0C 00 58 54 52 4B 5F 41 4E 47 4C 45 5F 43 44 00 00 00 04 FC 2D
FE 19 14 01 01 16 00 00 80 3F E8 00 0D 00 41 4C 54 5F 4D 49 58 00 00 00 00 00 00 00 00 00 09 F6 EF
FE 19 15 01 01 16 00 00 80 40 E8 00 0E 00 43 4D 44 5F 54 4F 54 41 4C 00 00 00 00 00 00 00 02 44 80
FE 19 16 01 01 16 00 00 00 00 E8 00 0F 00 43 4D 44 5F 49 4E 44 45 58 00 00 00 00 00 00 00 02 B1 0E
FE 19 17 01 01 16 00 00 F0 41 E8 00 10 00 57 50 5F 52 41 44 49 55 53 00 00 00 00 00 00 00 02 1A 38
FE 19 18 01 01 16 00 00 34 42 E8 00 11 00 57 50 5F 4C 4F 49 54 45 52 5F 52 41 44 00 00 00 02 2B FB
FE 19 19 01 01 16 00 00 00 00 E8 00 12 00 46 45 4E 43 45 5F 41 43 54 49 4F 4E 00 00 00 00 02 2B BC
FE 19 1A 01 01 16 00 00 00 00 E8 00 13 00 46 45 4E 43 45 5F 54 4F 54 41 4C 00 00 00 00 00 02 51 C1
FE 19 01 01 01 16 00 00 00 00 E8 00 E4 00 4D 4E 54 5F 43 4F 4E 54 52 4F 4C 5F 5A 00 00 00 09 2A 66
FE 19 02 01 01 16 00 00 00 00 E8 00 E5 00 4D 4E 54 5F 53 54 41 42 5F 52 4F 4C 4C 00 00 00 02 F6 55
FE 19 03 01 01 16 00 00 00 00 E8 00 E6 00 4D 4E 54 5F 53 54 41 42 5F 50 49 54 43 48 00 00 02 0B 57
FE 19 04 01 01 16 00 00 00 00 E8 00 E7 00 4D 4E 54 5F 53 54 41 42 5F 59 41 57 00 00 00 00 02 CF 48
还有,有些数据后边有规律的多出几个字节全是21 47,是怎么回事啊
发表于 2013-11-5 00:11 | 只看该作者
比如说这个MANUAL_LEVEL参数吧,其类型字节02,应该是int8,但值字段却是00 00 80 3F。这值到底是多少怎个顺序读呢?我真晕了
143
发表于 2013-11-5 21:29 | 只看该作者
已经搞定。原来不管神马类型参数,全统一成float单精度浮点了。
144
发表于 2013-11-7 06:03 | 只看该作者
截了很多数据分析。惊奇的发现成品APM2.52发出的每帧除了第一字节为FE以外,其它字节没有FE! 难道这是巧合,还是其中有神马转码机制?请楼主赐教。
145
发表于 2013-11-7 06:13 | 只看该作者
感谢楼主分享资料,让我学到很多
146
 楼主| 发表于 2013-11-8 00:53 | 只看该作者
agnd 发表于 2013-11-7 06:03
截了很多数据分析。惊奇的发现成品APM2.52发出的每帧除了第一字节为FE以外,其它字节没有FE! 难道这是巧合, ...
Arduplane 只用到了mavlink 100 多个 message 当中的十来个而已,如果没有碰到 0xfe,纯属巧合,呵呵
我接触过的协议里面还有用a55a作帧头标志的,但这个也不妨碍a55a在数据帧有效载荷中出现,只不过是几率小很多
147
 楼主| 发表于 2013-11-8 01:15 | 只看该作者
写了一大堆,一不小心没了,悲催阿
不好意思各位,近期杂事比较多,另外被游标拖动控件好好折磨了一回,所以就没有及时进行更新,不过一直在关注着帖子,感谢各位关注
游标拖动控件是一个比较重要的控件,重要之处就在于其具备数据输入和动作触发特性
游标控件的实现细节里面躲满了小魔鬼,略举一二
1、游标拖动到头后,鼠标当然要允许继续移动,但游标位置及其关联数据不能再变化
2、如果拖动到头超出一定范围后,鼠标反方向折返,那么
   2.1、当鼠标回到有效拖动范围内,游标位置及数据须随之改变
   2.2、鼠标折返时进入有效拖动范围后,鼠标位置与游标位置不能出现偏移,偏移累计
3、游标拖动改变数据的范围毫无疑问不能使在0-100期间定死不变。
4、游标拖动在改变数据数值时,应当根据该数据的数据精度确定数据变化的离散阶梯值
5、圆形游标拖动控件要考虑 0-360 度前后数值变化的问题
148
 楼主| 发表于 2013-11-8 01:18 | 只看该作者
另外对公式编辑器及数据处理通道进行了改进,现在数据处理通道支持100个自定义变量、80个直定义表达式参与实时运算
149
 楼主| 发表于 2013-11-8 01:20 | 只看该作者
416786163 发表于 2013-11-1 18:03
楼主,能不能出个详细的视频教程?
希望价格能亲民,好上手。
我一直有这个想法,但是用相机什么的拍视频效果不大好,屏幕录影软件也没找到合适的,您能否推荐个好方法?谢谢!
免费版自然不用说,现在来看,CSS是具有明确的应用背景了,推出个标准版其实也是顺手而为的事情,所以亲民那是必须的。您觉得价格在那个范围期间比较合适?
目前CSS的代码量基本接近早期版本的PhotoShop了,呵呵
另外在未来的beta测试过程中,参与测试并提出有价值建议意见的参与者,将无偿升级为标准版甚至是专业版,我想这样可能比较好。
好上手那我可不敢保证、帧编辑特性、总线编辑特性、条件触发-动作响应特性等等等等综合就是一个相对复杂的体系,对于使用CSS的开发人员而言。
不过对于CSS的使用人员而言,将来会提供几套不同风格的地面站模板,直接拿来用就是了,弄熟了还可以自己改着玩,呵呵
150
发表于 2013-11-8 04:31 | 只看该作者
scaple 发表于 2013-11-8 01:20
我一直有这个想法,但是用相机什么的拍视频效果不大好,屏幕录影软件也没找到合适的,您能否推荐个好方法 ...
尊重成果
Faststone
http://www.faststone.com/FSCaptureDetail.htm\
Camstudio, opensource free one
http://camstudio. o r g
Adobe captivate (the most expensive one, support HD, last choice)
http://thankyou.adobe.com/en/na/products/CP/v3/1106_captivate.html?sdid=EICKE&skwcid=TC|1026688|%2Badobe%20screen%20recorder||S|b|26614184302
151
 楼主| 发表于 2013-11-8 12:38 | 只看该作者
yun89708 发表于 2013-10-30 11:49
到现在也没见发布,吊人胃口!
谢谢你的鞭策,我会作为动力的,呵呵
按照原有设计,接下来把波形图和基本图元控件完成后就算基本完工了。不过仍然有后期的美工、使用文档的编写、相关网站的创建等一系列工作要做。
但是现在情况有了新的变化,根据试飞当中出现的新需求,接下来我的重点是对触发条件 - 响应动作机制进行较大幅度的功能增强,前面几天对公式编辑器/数据处理通道的修改也是为了同样的目的。这是一项很有意义的工作,我想也是APM体系将来的一个重点发展方向,具体是什么我想还是给大伙留个小小的悬念。这项工作需要很多的实际飞行作为验证,且伴有较大的风险。
昨天我躺在床上的时候突然想起来,理论上使用CSS提供的各种机制,可以搭建出一个简单的小游戏出来。等哪天有闲功夫的时候试试。
152
发表于 2013-11-9 19:18 | 只看该作者
有产品吗,哪里能看到学习一下,买一套。QQ247675958.
153
发表于 2013-11-9 21:11 | 只看该作者
给力!到时便宜点啊
154
发表于 2013-11-12 17:51 | 只看该作者
以前搞工控时用过几款组态软件,也许地面站做成这种模式更好。
155
发表于 2013-11-14 00:17 | 只看该作者
期待beta版早日发布,再次顶起
156
 楼主| 发表于 2013-11-14 12:40 | 只看该作者
条件触发 - 动作响应机制当中加入表达式解析运算
废了半天的劲,表达式这一块好长时间都没碰了,生疏很多了
这个条件-触发的设置的含义为:
当数据总线上的数据 Test_0 大于 3 时,计算表达式 Test_0 - 1.5 + Test_1 并把计算结果重新赋给 Test_0
这个我暂时称之为“瞬发数据处理机制”,与前面“数据处理通道”机制的不同之处在于
“数据处理通道”,是以实时、高速率的方式对数据处理通道当中的每个表达式进行运算处理,该通道当中的所有变量、表达式都是在系统初始化时统一分配创建的
“瞬发数据处理”,则是在某个事先预设的条件得到满足后触发执行的,其中的表达式、变量都是在执行的时候动态创建和销毁的
当然,无论是“数据处理通道”还是“瞬发数据处理”,其表达式都是在公式编辑器当中创建,其数据来源都来自于数据总线
157
发表于 2013-11-17 12:29 | 只看该作者
beta版什么时候会出啊
158
 楼主| 发表于 2013-11-26 00:14 | 只看该作者
冒个小泡,当前进展:
花絮:先前一次失控坠机撞墙的事后分析
159
发表于 2013-11-26 19:00 | 只看该作者
好贴呀 !!
160
发表于 2013-12-3 00:23 | 只看该作者
什么时候公测?
