庆祝阳光动力二号来到南京,这个周日会和老朋友们一起去欣赏,在wiki的网页上面找到一点点基本资料,仅对阳光动力二号的介绍部分翻译了一下,有错误的欢迎指出,禁止谩骂讥讽。原文在这里:https://en.wikipedia.org/wiki/Solar_Impulse
Design
设计
The wingspan of HB-SIB is 71.9 m (236 ft), slightly less than that of an Airbus A380, the world's largest passenger airliner,[25] but unlike the 500-ton A380, the carbon-fibre Solar Impulse weighs only 2.3 tonnes (5,100 lb), little more than an average automobile. It features a larger, non-pressurized cockpit and advanced avionics, including an autopilot to allow for multi-day transcontinental and trans-oceanic flights.[11] Supplemental oxygen and various other environmental support systems allow the pilot to cruise up to an altitude of 12,000 metres (39,000 ft).
HB-SIB翼展71.9米(236英尺),比A380的尺寸略小,A380是世界上最大的载人飞机,但并不像500吨的A380那么重。碳纤维的阳光动力2号仅重2.3吨,合5100磅,比一辆家用汽车略重,它有一个显眼的较大的非加压驾驶仓,配备先进的电子设备,包括可以连续多日横贯大陆或者越洋飞行的自动装置,供氧和其他环境保障系统俱全,保证飞行员可以巡航在12000米(39000英寸)的高度。
General characteristics
一般特性
Crew: 1
载人数量:1人
Length: 22.4 m (73.5 ft)
长度:22.4米(73.5英尺)
Wingspan: 71.9 m (236 ft)
翼展:71.9米
Height: 6.37 m (20.9 ft)
高度:6.37米
Wing area: 17,248 photovoltaic cells cover the top of the wings, fuselage and tailplane for a total area of 269.5 m2 (rated at 66 kW peak)
翼面积:17248块太阳能电池板覆盖机翼,机身和水平尾翼,总面积达到269.5平方米(最大额定输出功率66KW)
Loaded weight: 2,300 kg (5,100 lb)
载重:2300公斤(5100磅)
Powerplant: 4 × electric motors powered from solar cells and 4 x 41 kWh lithium-ion batteries (633 kg), providing 13 kW[19], electric motors (17.4 HP) each
动力:四台电机,由四块41KWH的锂聚合物电池(重633公斤)供电,每台电机可以输出13KW(17.4马力)的动力
Propeller diameter: 4 m (13.1 ft)
螺旋桨直径:4米(13.1英尺)
Take-off speed: 20 kts (36 km/h)
起飞速度:20节(36公里/小时)
Performance
性能
Maximum speed: 77 kts (140 km/h) 87 mph
最大速度: 77节(140公里/小时)87英里/小时
Cruise speed: 49 kts (90 km/h) (33 kts (60 km/h) at night to save power)
巡航速度:49节(90公里/小时),为节省能源,夜间飞行33节(60公里/小时)
Service ceiling: 8,500 m (27,900 ft) with a maximum altitude of 12,000 metres (39,000 ft)
飞行高度:8500米(27900英尺),最大高度为12000米(39000英尺)
