查看: 1493|回复: 0
求教!
发表于 2015-8-17 12:20 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
点击查看详情
Test: Autotune = NA -
Test: Balance/Twist = NA -
Test: Brownout = GOOD -
Test: Compass = FAIL - Large change in mag_field (358.80%)
Max mag field length (735.57) > recommended (550.00)
Test: Dupe Log Data = GOOD -
Test: Empty = GOOD -
Test: Event/Failsafe = GOOD -
Test: GPS = FAIL - Min satellites: 0, Max HDop: 99.99
Test: IMU Mismatch = GOOD - (Mismatch: 0.52, WARN: 0.75, FAIL: 1.50)
Test: Parameters = GOOD -
Test: PM = NA -
Test: Pitch/Roll = NA -
Test: Thrust = NA -
Test: VCC = GOOD -
pix起飞两秒开始“错误compass variance”后面刚一切手动就故障保护,没两秒GPS卫星数掉到0,然后就果不其然炸机了
