First flight with the ISO. All post completion checks went very well, with everything seeming to behave as it should.
Gear:
2X Sunnysky X2820 800Kv
2X Xoar 10X7
2X Turnigy D-lux 40A ESC
Frsky L9R RX with Taranis radio
3DR Pixhawk with Ublox GPS, 433Mhz telemetry and digital airspeed sensor.
5G8 600mw vtx
?from=s1.8-1-1.2
Had my second flight with the ISO yesterday. Was quite foggy so I didn't fly far, but I was trying more to test the efficiency. Annoyingly I turned off my goggles before stopping the dvr so I have no dvr footage. In general I was using between 7 and 10A for approximately 30 mph.
The video is fairly dull, but here it is!
Currently the vertical stabaliser is glued into a metal bracket, which is in turn glued to the horizontal stabaliser. This tail assembly is then mounted with two screws from the underside of the boom. The metal bracket overreacted for the screws. Folding the whole assembly would be tricky, however the tail could be removed in a minute by undoing the two screws. Obviously you would need a quick release sort of plug for the rudder and elevator wires.
I hope this is helpful. I'll add some more pics of this area tomorrow, which should make it easier to understand.
I gurantine u speak chinese right, and , is that the antenna for your telemetry? How much it takes to ship this plane to UK? I tried to ship a bixler to US, cost is ridiculous
