查看: 1217|回复: 7
请教老师
发表于 2016-3-26 18:19 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
点击查看详情
飞宇panda2飞控系统,增稳模式盘旋上升突然失控,猛抬头向上飞了5米左右急速俯冲炸机,求能看懂飞行数据的大师分析一下是什么原因导致失控万分感谢  飞机是i-soar one
#DATA1,29,241,249,9,255,9,137,19,24,25,44,37,38,30,137,0,191,43,45,0,196,2,123,0,2,0,0,93,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,12,3,23,16,24,0,211,2,50,10,50,10,216,170
#DATA3,53,243,0,119,128,3,10,52,11,104,14,122,11,138,0,0,55,0,142,0,160,0,63,48,29,87,1,166,7,218,255,202,226,229,255,228,255,231,255,128,0,7,0,0,9,146,255,246,255,104,0,150,170
#DATA1,29,241,248,9,255,9,137,19,42,25,44,37,194,33,97,0,198,43,37,0,206,2,121,0,2,0,0,236,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,13,3,23,16,24,0,202,2,56,10,50,10,214,170
#DATA3,53,243,0,97,0,12,10,216,11,82,14,126,11,140,0,0,55,0,145,0,138,0,64,48,245,122,0,30,8,253,255,202,226,251,255,228,255,231,255,2,0,8,0,0,9,22,0,28,0,82,0,80,170
#DATA1,29,241,247,9,255,9,137,19,27,25,44,39,15,39,201,0,209,43,38,0,221,2,120,0,2,0,0,179,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,16,3,23,16,24,0,196,2,69,10,50,10,224,170
#DATA3,53,243,0,64,128,104,10,68,11,104,14,124,11,128,0,0,55,0,149,0,115,0,66,59,6,0,254,115,8,4,0,202,226,212,255,228,255,231,255,231,255,1,0,0,8,236,255,22,0,172,0,73,170
#DATA1,29,241,248,9,255,9,137,18,244,25,45,0,167,43,46,0,213,43,30,0,226,2,105,0,2,0,0,89,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,17,3,23,16,24,0,199,2,75,10,50,10,234,170
#DATA3,53,243,0,53,128,41,10,126,11,106,14,124,11,146,0,0,56,0,151,0,102,0,67,57,229,177,252,60,8,45,0,202,226,182,255,228,255,231,255,221,5,2,0,0,8,8,0,26,0,45,0,67,170
#DATA1,29,241,248,9,255,9,137,18,184,25,45,1,73,46,16,0,216,43,20,0,234,2,97,0,2,0,0,158,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,246,52,6,29,18,3,23,16,24,0,203,2,81,10,50,10,246,170
#DATA3,53,243,0,37,0,4,10,82,11,116,14,124,11,142,0,0,55,0,154,0,91,0,68,57,177,139,251,4,8,61,0,202,226,163,255,228,255,231,255,220,5,3,1,0,9,170,255,10,0,80,0,128,170
#DATA1,29,241,247,9,255,9,137,18,25,25,45,2,144,48,199,0,218,42,251,0,244,2,69,0,2,0,0,213,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,20,3,23,16,24,0,197,2,94,10,50,0,244,170
#DATA3,53,243,0,11,0,80,10,118,11,100,14,124,11,152,0,0,56,0,159,0,78,0,71,53,1,113,250,199,7,97,0,202,226,67,0,228,255,231,255,215,5,5,0,0,7,247,255,238,255,232,255,69,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,21,3,23,16,24,0,209,2,100,10,50,1,8,170
#DATA3,53,243,0,147,128,64,11,74,10,240,14,126,11,146,0,0,55,0,162,0,81,0,72,62,148,200,250,215,7,2,0,202,226,244,1,228,255,231,255,137,0,6,1,0,16,75,0,135,0,53,0,234,170
#DATA1,29,241,249,9,255,9,137,17,2,25,45,3,248,61,172,0,184,43,212,0,177,3,4,0,2,0,0,79,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,24,3,23,16,23,0,234,2,114,10,50,0,48,170
#DATA3,53,243,0,227,128,211,10,200,11,84,14,126,11,124,0,0,56,0,167,0,103,0,74,75,245,118,249,44,2,23,253,202,226,238,2,228,255,231,255,2,0,8,0,0,9,246,255,68,0,163,0,119,170
#DATA1,29,241,249,9,255,9,137,16,156,25,45,4,16,69,106,0,160,44,35,0,173,3,89,0,2,0,0,80,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,25,3,23,16,23,0,213,2,121,10,50,1,36,170
#DATA3,53,243,0,62,128,72,8,250,13,82,14,46,11,104,0,0,55,0,169,0,106,0,75,73,159,55,249,234,255,52,253,202,226,69,3,228,255,231,255,228,255,0,254,0,252,156,254,243,253,201,0,242,170
#DATA1,29,241,248,9,255,9,137,16,45,25,45,4,16,70,134,0,156,44,85,0,204,3,102,0,2,0,0,87,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,26,3,23,16,23,0,219,2,127,10,50,2,50,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,245,52,6,29,27,3,23,16,23,0,153,2,133,7,50,0,242,170
#DATA3,53,243,129,94,2,2,10,78,12,94,14,46,11,162,0,0,55,0,174,0,116,0,77,38,198,131,244,132,255,151,254,202,226,13,250,228,255,231,255,221,5,2,0,0,254,177,255,111,255,161,255,243,170
#DATA1,29,241,245,9,255,9,137,14,215,25,45,4,7,71,168,0,240,44,119,1,47,1,226,0,2,0,0,106,170
#DATA2,44,242,1,1,47,0,50,0,170,9,137,16,207,25,45,1,46,9,137,16,213,25,45,1,34,0,246,52,6,29,28,3,23,16,23,0,103,2,137,9,50,0,200,170
#DATA3,53,243,129,249,3,95,10,0,12,90,14,46,11,156,0,0,56,0,177,0,133,0,79,72,159,111,244,251,254,72,255,202,226,172,245,228,255,231,255,220,5,3,1,0,249,45,0,78,255,192,255,203,170
 楼主| 发表于 2016-3-26 18:20 | 只看该作者
飞行数据太大 超出限制范围  剪切了最后几行  不知道行不行
发表于 2016-3-26 19:02 | 只看该作者
我先请教你下,熊猫2可以接摄像头,图传显示OSD吗?
发表于 2016-3-26 19:03 | 只看该作者
谢谢
 楼主| 发表于 2016-3-26 19:41 | 只看该作者
可以  我的没接
发表于 2016-3-26 20:14 | 只看该作者
请问外观是贴的贴纸吗?
发表于 2016-3-26 20:16 | 只看该作者
你这是poss数据啊,这个确实看不出来
 楼主| 发表于 2016-3-26 20:22 | 只看该作者
侯薛林 发表于 2016-3-26 20:16
你这是poss数据啊,这个确实看不出来
上半部分是贴纸  下半部分玻璃钢加固
