查看: 2166|回复: 7
450安装,调试,测试全教程,录像
发表于 2007-9-30 00:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
老外的网站,这个斑竹把自己的所有450经验全部拍成了录像短片。
从最简单的安装到复杂的调试,应有竟有,能想到的都有了。大家慢慢享受吧。
赞一个,老外的奉献精神。:em26: :em26:
http://www.helifreak.com/showthread.php?t=11373
Trex SE and general build videos are here
It was suggested by a excellent contributor GimbalFan that I order my videos in a order that should be follow by a new person (n00b) with a new Trex. I liked the suggestion and now the videos are in order as they should be viewed.
NEW VIDEOS added 8/28/2007!
My old beater SE got pretty totaled at IRCHA night flying (I wont explain but it wasnt me) and I had to do a rebuild. Thus I decided to do a video on things that I had not done on the SE before. That is a complete frame build (All 4 frame sides were broken in the crash) and HS65MG servo install. So with that here ya go:
NEW VIDEO -> Trex SE frame build (40 Megs)
NEW VIDEO -> Installing HS65MG servos in an SE (50 Megs)
Here are the other Trex 450 videos:
General Maintenance Ad-hoc Video (20 Megs)
Installing the NEW SE tail hub (20 Megs)
Modifying the new SE tail hub to make it much better (10 Megs)
Thread Lock 101 (15 Megs)
Installing HS56 Servos in a Trex SE (38 Megs)
Ball Links 101 (20 Megs)
Soldering Bullet (Motor) Connectors 101 (50 Megs)
Soldering Deans Connectors 101 (30 Megs)
Trex Electronics placement and overview (28 Megs)
CCPM Setup Part 1 (58 Megs)
CCPM Setup Part 2 (58 Megs)
Pitch and Throttle Curves 101 (58 Megs)
401 gyro setup (48 Megs)
Align ESC setup (30 Megs)
Blade Balancing (30 Megs)
Canopy Trimming 101 (28 Megs)
Servo Repair 101 (30 Megs)
Replacing the Align Auto-rotation Clutch (20 Megs)
Blade Tracking 101 (35 Megs)
Programming the Futaba 9Z for a heli (78 Megs)
Enjoy!
Bamboo
发表于 2007-9-30 00:51 | 只看该作者
顶一个,可惜听不懂E文:em17:
发表于 2007-9-30 01:13 | 只看该作者
正在下,看看怎么样吧。文件都好大啊
发表于 2007-9-30 07:19 | 只看该作者
:em15:
发表于 2007-9-30 09:31 | 只看该作者
呵呵!应该是AVI格式的吧?应该是很大的!:em15:
发表于 2007-9-30 18:34 | 只看该作者
不错:em24: :em15:
发表于 2007-10-1 02:03 | 只看该作者
:em26:
发表于 2007-10-1 11:23 | 只看该作者
不算太大.
10分钟50M
以下是部分视频的字幕链接
http://bbs.5imx.com/bbs/viewthre ... &extra=page%3D1
