查看: 7277|回复: 13
收索机及摇臂的设置
发表于 2008-12-24 11:25 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
The following is copyrighted by Hitec RCD, used with permission.
For a "continuous" sheeting system (figure A,B,C), both sections of the drum are used, so that the ends of the "loop" feed on and off the spools at the same rate. In addition to the number of turns required to trim the sail, place a extra half to full turn of string on the spool. In this example, the sail winch and its drum are located under the deck of the boat. Pulleys are used to allow the string to exit the deck and turn with little friction.
For a single "non-continuous" sheeting system (figure D), where tension is maintained by elastic, either spool can be used. In addition to the number of turns required to trim the sails, place a extra half to full turn of string on the spool. Run the string from the drum, through a pulley that allows the string to exit the deck. Attach elastic to string on the deck to keep tension on the string as winds on and off the spool.
Here's an alternative sheeting system using a Drum winch
参与人数 1威望 +2 收起 理由
论坛老模友 + 2 精品文章,感谢分享!
发表于 2012-8-20 11:02 | 只看该作者
不错
学习了!正要自己做一条帆船
发表于 2012-6-4 20:07 | 只看该作者
好东西,收藏:em26:
发表于 2012-6-3 01:40 | 只看该作者
的确好资料:em26:
发表于 2012-5-31 21:31 | 只看该作者
好资料,慢慢学!
发表于 2012-5-26 21:23 | 只看该作者
嘛?:em04:
发表于 2009-2-25 21:13 | 只看该作者
我有两个帆船用的收索机 HITEK HS-755HB 舵机。要我和我联系:619166000
发表于 2009-2-24 03:22 | 只看该作者
学习
发表于 2009-2-14 11:59 | 只看该作者
学习
发表于 2009-2-2 21:18 | 只看该作者
好东西
:em07:
发表于 2008-12-27 13:36 | 只看该作者
:em15: 谢谢分享,好资料
 楼主| 发表于 2008-12-24 14:23 | 只看该作者
看看图不就了解了,或者自己用软件翻译下:em15:
发表于 2008-12-24 12:17 | 只看该作者
晕啊,英文的……看不懂:em12:
 楼主| 发表于 2008-12-24 11:27 | 只看该作者
有的小船可以采用帆用舵机来控制,这样比较便宜,方案如下
或者在舵机中置的方式如下
