查看: 1779|回复: 0
IRCHA制定的直升机动作难度7个等级中英对照(第六
发表于 2003-7-2 06:24 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
第六级(Level VI)
     Level VI is an advanced level of proficiency and completion of this level takes the pilot to the level of a pilot capable of performing beyond the basics of Sideways Flight. Intrinsic to this level is successfully completing all components of the previous levels, then advancing to the ability to control the helicopter in these new orientations. Please use extreme caution when performing these advanced maneuvers, the pilots and spectators safety is of utmost importance.
    第六级属於高级程度,使操控者有能力执行基础的横向飞行。第六级的本质是要能成功地完成前五级的所有动作,以及增进对於新动作的操控及定位能力。在执行这些高级的动作时,必须尽可能地注意操控者及观众的安全。
Sideways Flight(横向飞行水平圆)
    1.With the helicopter upright hovering Tail-In over the landing circle, fly sideways for at least one (1) clockwise and one (1) counterclockwise circuit around your flying area. The nose of the helicopter must be pointing toward the center of the flight area.
    在降落区的上空将机尾朝向操控者保持停悬,在飞行区内以横向飞行的方式,对顺时针及逆时针的方向,至少各执行一圈机头朝向圆心的水平圆。
    2.With the helicopter rpright hovering Nose-In over the landing circle, fly sideways for at least one (1) clockwise and one (1) counterclockwise circuit around your flying area. The nose of the helicopter must be pointing away from the center of the flight area.
    在降落区的上空将机头朝向操控者保持停悬,在飞行区内以横向飞行的方式,对顺时针及逆时针的方向,至少各执行一圈机尾在降落区的上空将机尾朝向操控者保持停悬,在飞行区内以横向飞行的方式,对顺时针及逆时针的方向,至少各执行一圈机头朝向圆心的水平圆。朝向圆心的水平圆。
Sideways Figure of Eight - Flying(横向8字飞行)
   1.With the helicopter hovering Nose-Out over the landing area, move the helicopter sideways to the right, perform a 270 degree Nose-In turn. The helicopter should now be flying sideways directly at the pilot.
    在降落区的上空将机尾朝向操控者保持停悬,向右侧横向飞行,执行机头向内3/4水平圆,使机身右侧朝向操控者。
   2.While maintaining constant altitude and speed, execute a 360 degree Nose-Out turn, the helicopter should be flying sideways directly at the pilot again.
   保持固定的高度及速度,向另一侧执行机尾向内360°水平圆,此时机身右侧又再一次朝向操控者。
   3.Perform a 90 degree Nose-In turn fly sideways straight and level, completing the maneuver. Fly back to the starting point above the landing area.
   再执行机头向内1/4水平圆後便完成此动作。将直升机飞回降落区上空的起始点。
   4.Repeat the maneuver but this time start flying sideways to the left.
    向左侧横向飞行,重覆执行上述的步骤。
   5.With the helicopter hovering Nose-Right over the landing area, move the helicopter sideways directly away from the pilot, perform a 360 degree Nose-In turn. The helicopter should now be flying sideways directly away from the pilot.
    在降落区的上空将机头朝右保持停悬,向外侧(飞离操控者)开始横向飞行,执行机头向内360°水平圆,使机身侧面朝向操控者。
   6.Complete the maneuver by performing a 360 degree Nose-Out turn. The helicopter should again be flying sideways directly away from the pilot.
    再向另一侧执行机尾向内360°水平圆後便完成此动作,此时机身侧面又再一次朝向操控者。
   7.Repeat the maneuver, but this time start with the helicopter hovering Nose-Left.
    将机头朝左保持停悬,重覆执行步骤5及6。
Sideways Inside Loops(横向内浸斗)
    1.With the helicopter upright flying sideways Tail-In straight and level from left to right, as the helicopter passes in front of the pilot, apply collective and left cyclic to complete an inside loop.
    保持机尾朝向操控者,由左向右开始横向水平飞行,当直升机通过操控者的前方时,加大主旋翼的螺距并且将副翼打左舵完成一个内浸斗。
    2.Repeat with the helicopter flying sideways from right to left, and right cyclic.
    重覆执行步骤1,但由右向左开始横向水平飞行,并且将副翼打右舵完成一个内浸斗。
    3.Repeat both of the above loop, but this time the helicopter must be Nose-In to the pilot.
    保持机头朝向操控者,重覆执行步骤1及2。
Sideways Outside Loops(横向外浸斗)
   1.With the helicopter upright flying sideways straight and level from left to right, as the helicopter passes in front of the pilot, apply collective and right cyclic to complete an outside loop.
    保持机尾朝向操控者,由左向右开始横向水平飞行,当直升机通过操控者的前方时,加大主旋翼的螺距并且将副翼打右舵完成一个外浸斗。
   2.Repeat with the helicopter flying sideways from right to left, and left cyclic.
    重覆执行步骤1,但由右向左开始横向水平飞行,并且将副翼打左舵完成一个外浸斗。
Sideways Rolls(横向滚翻)
   Note∶A "roll" while flying sideways can be thought of in two different way.
   注意∶当直升机保持横向飞行时,有二种不同的方式执行"侧滚"的动作。
1) In the normal way of rolling as a helicopter would normally fly or as
   如同执行一般的侧滚动作或是
2) A roll as compared to the current direction of flight.
   相对於目前飞行方向的侧滚动作。
  So we will do both!
  所以两者的动作我们都要执行!
Sideways Rolls - Helicopter is Rolling(横向滚翻 - 机体侧滚)
    1.With the helicopter flying sideways Nose-Out straight and level from right to left, roll the helicopter to the left (the same direction as the helicopter is flying), use collective to maintain altitude and speed across the ground, complete at least one (1) roll. Exit by flying away sideways straight and level.
    保持机尾朝向操控者,由右向左开始横向水平飞行,将副翼打左舵(与横向飞行的方向同向),控制主旋翼的螺距,使机体能保持固定的高度及横向速度,至少完成一个侧滚。动作结束时保持横向水平飞行。
   2.Repeat step a, but this time make the roll to the right (opposite the direction the helicopter is flying).
    将副翼打右舵(与横向飞行的方向逆向),重覆执行步骤1。
   3.Repeat steps a & b, but this time with the helicopter Nose-In to the pilot.
    4.Repeat steps a, b & c, but this time with the helicopter flying from left to right.
     由左向右开始横向水平飞行,重覆执行步骤1、2及3。
Sideways Rolls - Helicopter is Tumbling(横向滚翻 - 机体前後滚翻)
   a.With the helicopter flying sideways Nose-Out straight and level from right to left, tumble the helicopter forward while traveling sideways, use collective to maintain altitude and speed across the ground, complete at least one (1) tumble. Exit by flying away sideways straight and level.
    保持机尾朝向操控者,由右向左开始横向水平飞行,将升降舵打降舵,控制主旋翼的螺距,使机体能保持固定的高度及横向速度,至少完成一个前滚翻。动作结束时保持横向水平飞行。
   b.Repeat step a, but this time make the tumble backward.
     升降舵拉升舵,重覆执行步骤a。
   c.Repeat steps a & b, but this time with the helicopter Nose-In to the pilot.
     保持机头朝向操控者,重覆执行步骤a及b。
    d.Repeat steps a, b & c, but this time with the helicopter flying from left to right.
    由左向右开始横向水平飞行,重覆执行步骤a、b及c。
Pirouetting Figure of Eight(机体自旋8字飞行)
   1.With the helicopter hovering over the landing area, start pirouetting clockwise while the helicopter is pirouetting fly the helicopter in a Figure of Eight to the right. So at the center of the Eight, the helicopter is flying toward the pilot.
    在降落区的上空将直升机保持停悬,机体以顺时针的方向保持自旋,并且朝右侧开始执行外侧水平8字飞行。在8字形的中心点时,直升机是飞向操控者。
   2.Repeat the above step, but this time start pirouetting counterclockwise.
    机体以逆时针的方向保持自旋,重覆执行步骤1。
   3.Repeat step 1 above, but this time start the Figure of Eight by flying away from the pilot, pirouetting clockwise. So at the center of the Eight, the helicopter is flying away from the pilot.
    机体以顺时针的方向保持自旋,并且朝右侧开始执行内侧水平8字飞行。在8字形的中心点时,直升机是飞离操控者。
   4.Repeat the above step, but this time start pirouetting counterclockwise.
    机体以逆时针的方向保持自旋,重覆执行步骤3。
Inverted Pirouetting Figure of Eight(机体倒飞自旋8字飞行)
    1.With the helicopter inverted hovering over the landing area, start pirouetting clockwise while the helicopter is pirouetting fly the helicopter in a Figure of Eight to the right. So at the center of the Eight, the helicopter is flying toward the pilot.
    在降落区的上空将直升机保持倒飞停悬,机体以顺时针的方向保持自旋,并且朝右侧开始执行外侧水平8字飞行。在8字形的中心点时,直升机是飞向操控者。
