查看: 1623|回复: 0
[转帖]Two more maneuvers for your 3D bag of tricks.
发表于 2003-2-10 05:51 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
If you read our previous article on 3D flying, Wild Card CAP in the Summer Quarterly 1999, you'll remember we talked about five main 3D maneuvers:
The Harrier - very slow forward flight in a very nose high (about 45 degrees) attitude.
Torque roll
- "hovering" vertically in place, rotating left around its roll axis.
The Elevator - where the plane drops vertically while in a nose high attitude.
Waterfall - a continuous tail-over-nose descending flip. It is not a loop, but the aircraft actually flops around its canopy.
The Blender - a vertical diving roll that virtually stops its descent as it instantaneously enters into a flat spin.
Since we covered them in that first article, let's jump right into two new ones that are a lot of fun.
The Wall The Parachute
These two new maneuvers are a great addition to your repertoire. And once you've mastered them, here's a knock-'em-dead combo that's become one of my favorites to do with the Extra:
Takeoff normally, but as soon as the Extra is airborne, chop the throttle and do the Wall, then transition into a Torque Roll over the runway.
But one thing's for sure, you're going to want to practice all of this stuff up high before you try that!
http://f3a.tia.idv.tw/phpbb2/index.php
