查看: 23957|回复: 76
T8FG/T12FG 工程模式SD卡自动创建程序
发表于 2010-6-18 22:54 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Tools to create futaba T8FG service activator SD card.
1. Make sure the SD card was proper formatted by T8FG trasmitter.
(No matter there is model data in it)
2. Insert card to SD card reader and run T8FGService.exe
3. Select the correct drive where your SD card is in.
4. Click ok and wait the procedure complete.
5. Eject the card and insert into T8FG
6. Powre on T8FG and the service menu appears automaticly.
7. When your want reuse the SD card in T8FG to store model data. Just delete TINYFS.IMG in card root directory or format the card in OS.
** WARRING: OWN YOUR RISK TO MODIFY SERVICE MENU SETTINGS **
Futaba T8FG 工程模式激活工具
1. 把SD卡放入控中格式化 (无需空卡)
2. 把SD卡放入读卡器,并启动 T8FGService.exe 程序
3. 选择SD卡对应的驱动器符
4. 点击“OK”等操作完成
5. 弹出SD卡,插入T8FG中
6. 打开T8FG电源,工程菜单会自动显示
7. 如果还需要使用这张卡存放模型数据,删除TINYFS.IMG文件或在操作系统中格式化。
** 警告:小心使用工程菜单,自担风险 **
modify KEY.dat file to do other function. (Any string else to disable service function)
'T8FG  TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T8FG  TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T8FG  TEST(RST SS )' - Don't Known SS stands for
'FX-20 TEST(RST SS )' - Do service FX-20, Don't know SS.
'T8FG  TEST(RST PCM)' - Don't Known detail, maybe reset PCM module locate
'FX-20 TEST(RST PCM)' - Do service FX-20, Reset PCM Module.
'T8FG  TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T8FG  TEST(TELEC  )'  - Don't known what's purpose
'T8FG SCREEN SHOT   ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
'T8FG  TEST SHOT    '  - maybe simular to screen shot
This program can be used for T12FG too. Just use following code in KEY.dat instead.
'T12FG TEST(NORESET)' - Shows all service menus and allows making all the changes.
'T12FG TEST(LIMIT  )' - Shows only a sub-set of service menus, with limited editing possibilities. E.g. Cannot change the product id, band, area...
'T12FG TEST(RESET  )' - Hard reset of the TX. All memory is cleared, total power on time is reset, product id is cleared, stick calibration is reset...
'FX-30 TEST(RESET  )' - I don't have FX-30, so I never tried it. Don't know what it does.
'T12FG TEST(NOEDIT )' - Shows all service menues, but prevents any changes. Includes an RF test screen.
'T12FG SCREEN SHOT  ' - A screen shot of TX can be made with SW-H. Screen shots are stored on SD card and can be extracted with ffs.exe tool.
下 载地址:
http://starmoon.org.cn/share/software/RC/T8FGService.rar
发表于 2010-6-18 22:57 | 只看该作者
高人
发表于 2010-6-18 23:00 | 只看该作者
:em15: 已经使用成功,很不错的。。。所都SD卡基本都支持。。。:em15:
LZ的共享精神绝对要挺。。。:em26:
发表于 2010-6-18 23:01 | 只看该作者
:em26:
发表于 2010-6-18 23:06 | 只看该作者
:em26: :em26:
发表于 2010-6-18 23:15 | 只看该作者
楼主辛苦了
发表于 2010-6-18 23:31 | 只看该作者
:em26:
发表于 2010-6-18 23:40 | 只看该作者
非常不错! :em26:
发表于 2010-6-19 01:09 | 只看该作者
支持门叔!
发表于 2010-6-19 02:11 | 只看该作者
弄完手动又有自动了,哈哈
发表于 2010-6-19 07:16 | 只看该作者
:em26: :em26: :em26:
发表于 2010-6-19 08:00 | 只看该作者
LZ强大啊。。。狂顶
发表于 2010-6-19 09:12 | 只看该作者
庆幸自己买了8FG:em15:
发表于 2010-6-19 11:41 | 只看该作者
收藏了~~~~~~~~
发表于 2010-6-19 13:58 | 只看该作者
用工程模式的好處是什麽?:em04:
发表于 2010-6-19 16:36 | 只看该作者
补充个很有用的小软件,主要是用于T12FG/T8FG模型数据的保存、交换和恢复的。
Futaba File System Utility for T12FG/T8FG
 楼主| 发表于 2010-6-19 21:56 | 只看该作者
我早就用这个把我的模型数据都备到电脑里了,SD卡里也存一份
发表于 2010-6-20 00:28 | 只看该作者
启动 T8FGService.exe 程序无法写入SD卡内,请问是什么问题?此卡能格式化,保存模型资料正常,能给张写入成功的图片看看吗?谢谢了
发表于 2010-6-20 00:45 | 只看该作者
非常感谢!!
[ 本帖最后由 Sevfen 于 2010-6-20 00:47 编辑 ]
 楼主| 发表于 2010-6-20 00:47 | 只看该作者
原帖由 pz197361 于 2010-6-20 00:28 发表
仔细看说明,卡需在控里正常格式化后再写入。
你无法写入提示什么?
