define format ( / G6 S T M1 M2 L P D E H O )
address width = 1
field width = 2
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = none
not permanent
not modal
metric formats
leading zeros = false
trailing zeros = true
decimal point = false
decimal places = 0
imperial formats
decimal places = 0
end define
define format ( N )
address width = 1
field width = 4
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = none
permanent
not modal
metric formats
decimal places = 0
imperial formats
decimal places = 0
end define作者: Lancrey 时间: 2010-12-25 12:51 标题: 接着 define format ( G1 G2 G3 G4 G5 G7 )
address width = 1
field width = 2
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = none
not permanent
modal
metric formats
decimal places = 0
imperial formats
decimal places = 0
end define
define format ( X Y Z R B C )
address width = 1
field width = 8
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = if negative
not permanent
modal
metric formats
trailing zeros = false
decimal point = true
decimal places = 3
imperial formats
decimal places = 4
end define
define format ( I J K )
address width = 1
field width = 8
exponent width = 0
scale factor = -1
scale divisor = 1
tape position = 0
print position = 1
sign = if negative
not permanent
not modal
metric formats
decimal places = 3
imperial formats
decimal places = 4
end define
define format ( R2 Z2 Q1 )
address width = 1
field width = 8
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = if negative
not permanent
not modal
metric formats
decimal places = 3
imperial formats
decimal places = 4
end define
define format ( Q A U V W )
address width = 1
field width = 2
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = if negative
not permanent
not modal
metric formats
decimal places = 0
imperial formats
decimal places = 0
end define
define format ( F )
address width = 1
field width = 2
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = if negative
not permanent
modal
metric formats
decimal places = 0
imperial formats
decimal places = 0
end define
define format ( MS EM OP )
address width = 1
field width = 0
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = none
not permanent
not modal
metric formats
decimal places = 0
imperial formats
decimal places = 0
end define
define format ( ID )
address width = 1
field width = 4
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = none
not permanent
not modal
metric formats
leading zeros = true
decimal places = 0
imperial formats
decimal places = 0
end define
define format ( null )
address width = 0
field width = 0
exponent width = 0
scale factor = 1
scale divisor = 1
tape position = 0
print position = 1
sign = none
not permanent
not modal
metric formats
decimal places = 0
imperial formats
decimal places = 0
end define
# linked words
define format ( MS )
link to EM
end define作者: Lancrey 时间: 2010-12-25 12:52 标题: 再接 word order = ( OP N G1 G2 G3 G4 G5 )
word order = ( + G6 G7 X Y Z B C )
word order = ( + I J K R D S T )
word order = ( + H M1 M2 MS msg EM Q )
word order = ( + Q1 Z2 R2 ID F )
define keys
blocknumber = N
preparatory function = G1
aux function = M1
x feedrate not used
y feedrate not used
z feedrate not used
circle angle not used
x coordinate = X
y coordinate = Y
z coordinate = Z
key i = I
key j = J
key k = K
feedrate = F
feedrate per revolution = F
spindle = S
tool number = T
cycle dwell not used
dwell = X
tool length = H
tool radius = D
drill peck depth = Q1
drill hole depth = Z2
clearplane = R2
message start = MS
message end = EM
opskip = OP
radius = R
program id = ID
azimuth axis = B
elevation axis = C
3rd rotation axis = null
leader not used
x vector not used
y vector not used
z vector not used
end define
define codes
rapid = G1 0
linear = G1 1
circle cw = G1 2
circle ccw = G1 3
dwell = G6 4
xy plane = G3 17
zy plane = G3 19
xz plane = G3 18
compensation off = G2 40
compensation on left = G2 41
compensation on right = G2 42
imperial data = G4 20
metric data = G4 21
absolute data = G5 90
incremental data = G5 91
from = G3 54
feedrate per minute not used
feedrate per revolution not used
spindle rpm not used
constant surface speed not used
drill = G4 81
break chip = G4 82
deep drill = G4 83
tap = G4 84
bore 1 = G4 85
bore 2 = G4 86
bore 3 = G4 87
bore 4 = G4 88
bore 5 = G4 89
end of drill = G4 80
macro start not used
macro end not used
macro call not used
cycle retract = G6 99
tool length offset = G6 43
spline not used
stop = M1 0
opt stop = M1 1
spindle on cw = M1 3
spindle on cc = M1 4
spindle off = M1 5
spin coolant on cw = M1 13
spin coolant on ccw = M1 14
spin coolant off = M1 5
change tool = M1 6
coolant on mist = M1 7
coolant on = M1 8
coolant on flood = M1 8
coolant off = M1 9
clamp on not used
clamp off not used
end of tape = M1 2
end of prog = M1 30
gear range 1 not used
gear range 2 not used
gear range 3 not used
constant contour speed not used
constant contour speed 2 not used
word drill not used
word break chip not used
word deep not used
word tap not used
word bore 1 not used
word bore 2 not used
word bore 3 not used
word bore 4 not used
word bore 5 not used
end define作者: Lancrey 时间: 2010-12-25 12:52 标题: 最后 print header = "Delcam Postprocessor"
machine name = "Fanuc6m version 1.2"
point = "."
zero = "0"
tape headers = 1
integer 6 = 2
integer 7 = 1
integer 10 = 2
integer 11 = 1
integer 12 = 1
tool reset coordinates = 2
cycle output = 1
integer 20 = 1
block start = 10
block increment = 10
split move = 0
integer 26 = 1
program id start = 1
integer 34 = 3
integer 35 = 1
integer 36 = 1
integer 37 = 2
rapid feed code = 0
maximum block number = 0
maximum tape blocks = 0
minimum tape blocks = 0
segment type = 0
counter start = 0
counter increment = 0
tape split retract distance = -999
multiaxis coordinate transform = true
message output = false
block order = false
tlo output = true
tape split on tool change = false
full circle = true
incremental centre = true
go home output = false
use partid = true
use progid = true
spindle x motion = false
spindle y motion = false
spindle z motion = true
spindle w motion = false
spindle azimuth rotation = false
spindle elevation rotation = false
linearise multiaxis moves = true
use hole top in cycles = false
knot vector type = none
units = input
coordinates = absolute
azimuth axis units = none
azimuth axis direction = none
elevation axis units = none
elevation axis direction = none
spline type = none
maximum feedrate = 9999.0000
minimum feedrate = 1.0000
rapid feedrate = 9999.0000
maximum tape length = 0.0000
maximum segment = 0.0000
diameter = 1.0000
withdrawal amount = 50.0000
