查看: 2227|回复: 13
Team BlackSheep 推出整套FPV装备,2000美元
发表于 2011-2-26 02:34 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
phase.Airframe        Ritewing Zephyr (54" wingspan flying wing)
Power System        Hacker A-30L
70A Graupner BRUSHLESS CONTROL ESC
Aeronaut Propadapter
10x6 Graupner CAM folding prop
Team BlackSheep high-strength motor mount
Battery
(not included!)        2x 3300mAh 4S Turnigy NANO-TECH
must be purchased separately due to shipping policies
FPV Camera        Pixim 540TVL camera
FPV Transmitter        2.4GHz LawMate - only for export!
not compatible with 2.4GHz R/C systems
FPV OSD / HUD        EzOSD & EzCurrentSensor
R/C System        2x Graupner digital high speed 8kg/cm servos
8ch EzUHF Diversity Receiver
2x hand-tuned 433MHz Antennas
Other        Team BlackSheep RTF low noise wire harness
Team BlackSheep custom filtered powersupply
Performance figures:Cruise flight duration        50 minutes
Average flight duration        30 minutes
Travel distance         30 - 40 km
Operating range        15km / 9mi with 14dbi Patch Antenna
45km / 30mi with 24dbi Grid Antenna
Cruise speed        55 km/h
35 mph
Maximum speed
(level flight)        135 km/h
85 mph
Altitude ceiling
(ASL)        7000 meters
23000 feet
Maximum climb        5000 meters
16500 feet
Payload        Up to 500g
1.1 lb
All-up weight        2.2kg
4.85 lb
What you need if you're getting into FPV
If you are new to FPV we recommend the following equipment to get you started. Do not invest into too complex systems at the start. Down the road you can always add so-called video diversity (2 receivers and a device in the middle to select the best video quality), automated antenna tracking, redundant power supplies and so on. Start out with the basics and expand as you gain experience and reach limitations.
This list assumes you have all the R/C equipment (transmitter, charger, tools) required to fly planes visually.         Budget solution        Deluxe solution
Goggles        EVG920        CarlZeiss Cinemizer Plus
R/C System        Standard 35MHz/72MHz system
(remove EzUHF receiver from kit purchase)        EzUHF Transmitter
FPV Receiver        Lawmate Standard 2.4GHz Receiver        Lawmate Portable 2.4GHz Receiver
FPV Antenna        use included antenna (2km/1.5mi range)        14dbi Patch antenna (15km/10mi range)
Video splitter        not needed        4ch RangeVideo Videosplitter
Recorder        not needed        Lawmate PV-500 ECO or EVO
Ground Station battery        3S 2200mAh        3S 5800 mAh
Accessory        Camera tripod to mount and aim ground station antenna and receiver
Buy & customize
No EzUHF receiver (- US$ 149.95)
Add EzUHF Transmitter (+ US$ 259.95)
Tuned Lawmate Transmitter (+ US$ 99.90)
EzUHF Nagoya Transmitter Antenna (+ US$ 24.90)
Total: US$ 1,999.00
Payment possible via PayPal/CreditCard or Bank Transfer. All prices are excluding shipping and bank transfer or PayPal charges. On Aircraft kits a minimum of 50% must be paid in advance to confirm the order, the rest on delivery.
My Shoppingcart
cart empty
Product preview
http://www.team-blacksheep.com/videos
发表于 2011-2-26 09:31 | 只看该作者
浮云~!
发表于 2011-2-26 12:23 | 只看该作者
神马
发表于 2011-2-26 13:28 | 只看该作者
违规贴!请发到交易区!监定完毕!:em15:
发表于 2011-2-26 14:22 | 只看该作者
果然是神马.............
发表于 2011-2-26 18:34 | 只看该作者
:em22:
发表于 2011-2-26 18:37 | 只看该作者
比FY的差的多了!
发表于 2011-2-26 19:29 | 只看该作者
神马都是浮云~!:em15:
发表于 2011-2-26 21:22 | 只看该作者
看来都很蛋腚:em15:
发表于 2011-2-26 22:47 | 只看该作者
E文的不懂。
发表于 2011-2-26 23:54 | 只看该作者
这套系统如果是RMB2000,加上433的电台,还算有点性价比的
发表于 2011-2-26 23:58 | 只看该作者
:em22:
发表于 2011-2-27 00:21 | 只看该作者
一万四不到。。。
花这么多钱兄弟不少了吧?:em21:
有那个达到人家的水平了。。。。都是煮熟的鸭子。。嘴硬。。。:em15:
差距啊。。。
多好,一步到位!:em15:
赶紧都去买吧。。:em26:
发表于 2011-2-27 00:58 | 只看该作者
小半辆QQ就没有了。
