查看: 2080|回复: 4
DS95从技术参数上看能锁500的飞机啊!
发表于 2011-3-3 20:13 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
最近从一个网站上看到DS95和DS8910A+性能很接近啊,不知能不能锁500的尾巴?
DS-8910A+
Dead band: 0.0008ms (Default)
Control System:  +Pulse Width Control
Working frequence: 760us/560Hz
(RX) Required Pulse: 3.0~6.0 Volt Peak to Peak Square Wave
Operating Voltage: 4.8~6.0 V DC Volts
Operating Temperature Range:  -10 to + 60 Degree C
Operating Speed (4.8V): 0.052 sec/60° degrees at no load
Operating Speed (6.0V): 0.040 sec/60° dagrees at no load
Stall Torque (4.8V): 2.1 kg-cm (29.16oz/in)
Stall Torque (6.0V): 2.6 kg-cm (36.11 oz/in)
360° Modifiable: NO
Motor Type: Coreless Motor
Potentiometer Drive: Indirect Drive
Driver Type: FET
Bearing Type: Dual Ball Bearings
Gear Type: Titanium Gears
Programmable: NO
Connector Wire Length: 15.0 cm (5.9 in)
Dimensions: 35.8X15.2X29 mm (1.41x 0.6x 1.14 in)
Weight: 28g (0.99oz)
DS95
Dead band: 0.001ms (Default)
Working frequence: 1520μs / 333hz
(RX) Required Pulse: 3.0~5.0 Volt Peak to Peak Square Wave
Operating Speed (4.8V):  0.066 sec/60° degrees at no load
Operating Speed (6V): 0.053 sec/60° dagrees at no load
Stall Torque (4.8V): 2.44 kg-cm (33.88oz/in)
Stall Torque (6V): 3.05 kg-cm (42.36oz/in)
360° Modifiable:  YES
Potentiometer Drive: Direct Drive
Driver Type: FET
Gear Type: Chrome gear
Programmable: NO
Connector Wire Length: 20.0 cm (7.86 in)
Dimensions: 23X12X27.25 mm (0.9X0.47X1.07 in)
Weight:  21.21 g (0.74 oz)
发表于 2011-3-3 22:00 | 只看该作者
:em20: 完全不合適    千萬別嘗試呀!!
发表于 2011-3-6 00:08 | 只看该作者
是为何呢?仅仅是尺寸大小的区别不合适还是什么道理呢?
 楼主| 发表于 2011-3-6 12:50 | 只看该作者
同问
发表于 2011-3-6 17:42 | 只看该作者
用在450锁尾巴估计没问题。。
