查看: 2838|回复: 15
VBar 5.2升级将于九月一日发布
发表于 2011-8-26 05:16 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
http://www.vstabi.info/en/node/1120
最大的变化是Mini也会有定速了, 另外这次是Express和Pro都有的, 不像5.1只有Pro
发表于 2011-8-26 08:19 | 只看该作者
:em07: :em07: :em07:
发表于 2011-8-26 09:34 | 只看该作者
謝謝樓主:em26:
Version 5.2 Release at 1st September 2011
25 August, 2011 - 23:14 — ulrich
At the 1st of September we release the 5.2 Firmware and PC Software to our customers. Since it is a minor enhancement, the update is free for all 5.x users.
The 5.2 will be available as online update for the express owners too, which will still have the same functionality as express before, but with the new 5.2 enhancements at the algorithms.
Whats new:
The "pro" version of the mini will now have a governor too, same as the fullsize one. Due to limited ports at the mini unit the governor can only be used in combination with a Spektrum, a s-Bus or M-Link or a classic single line reciver. An external reciver with governor is not possible.
The Governor has been massively rewoked, mainly to better support electric governing. This gives a completely new option with most simple electric speedcontrollers. So even a simple controller turns into a high quality governor.
Setting up an electric governor has been greatly simplified. The default settings will match most usual installations, so there is no extensive tuning process needed.
The Integration between the governor an the rest of the algorithms has been improoved, so the complete control loop works smoother and quicker.
New security functions avoid unintended hot starts of the motor, which can turn into dangerous with electrics. This adds top level protection to simple ESC′s as well.
The piruette compensation has been improved. Complex moves will be smoother and more precise now.
Both versions will be available in paralell, so you can choose between 5.1 and 5.2 at any time.
The Update prcoess will be performed by a new pc software with the known method. The location of the software will be announced at the 1th. The settings will be taken over, so no new programming needed, just as you know from former updates.
[ 本帖最后由 kevin401 于 2011-8-26 09:44 编辑 ]
发表于 2011-8-26 09:39 | 只看该作者
:em26: 我等...还好没更新5.1PRO...:em15:
发表于 2011-8-26 12:33 | 只看该作者
:em24:
发表于 2011-8-26 12:36 | 只看该作者
以后大Vbar是不是要停产了呀   看样子3G系统一体化是趋势啊
发表于 2011-8-26 13:20 | 只看该作者
又要付费300+?
 楼主| 发表于 2011-8-26 14:51 | 只看该作者
原帖由 neohack 于 2011-8-26 09:39 发表
原帖由 chenwei5105729 于 2011-8-26 13:20 发表
又要付费300+?
这个倒不会, 就像之前5.0Pro到5.1Pro是免费的, 已经升了5.1Pro的话这次升5.2Pro也是免费的
[ 本帖最后由 JimmyZ 于 2011-8-26 15:00 编辑 ]
 楼主| 发表于 2011-8-26 14:53 | 只看该作者
原帖由 kevin401 于 2011-8-26 09:34 发表
謝謝樓主:em26:
At the 1st of September we release the 5.2 Firmware and PC Software to our customers. Since it is a mino ...
不客气:em15:
 楼主| 发表于 2011-8-26 14:56 | 只看该作者
原帖由 garfieldhummer 于 2011-8-26 12:36 发表
怎么会, 油机还得用大的, 还有像真机什么的, 官方的特性比较表:
http://www.vstabi.info/en/featurematrix
发表于 2011-8-26 15:03 | 只看该作者
用CGY750的飘过。不用当心升级给钱:em15:
发表于 2011-8-26 15:20 | 只看该作者
我觉得软件升级是理所当然的,肯本不应该收费。
 楼主| 发表于 2011-8-26 15:44 | 只看该作者
原帖由 li2898738 于 2011-8-26 15:20 发表
要说的话, 升5.2express也是免费的
MB卖1k, VBar卖2k也有人买, 你把它看成VBar卖2k, VBar Pro卖2k3就行了, 当然会有人买的, 一样道理
发表于 2011-8-26 20:05 | 只看该作者
这个不错  升了有什么好处?:em15:
发表于 2011-8-27 01:53 | 只看该作者
好象博士帽Express到5.2还是没得吧
发表于 2011-8-31 20:59 | 只看该作者
明天就可以升级了:em19:
