查看: 7108|回复: 12
发些英国PRESTWHICH的资料(也就是著名的英国老头马力斯的船)
发表于 2004-12-25 21:09 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
PUMA and COUGAR DEEP V RACERS
PUMA
           42" (1060mm) long racing Deep V . Made from white gelcoated fibreglass with prejoined hull deck for 10 to 15cc engines. (.61 to .90)  £139.00  Deltaforce
     Hardware as shown in the picture. Each boat’s hardware kit is purpose made for that particular boat.
     Hardware kit of flexi-shaft, strut, tube, brackets,  Wedge aluminium rudder with built in water-pickup and long brackets. £68.00. Optional parts: Epoxy glass lowline radio box. £13.00, Engine mount £12.20
PUMA Low cost deal
Consists of Puma boat with SC61(10cc) marine engine, steel manifold (header), silenced tuned pipe, quiet engine mount, coupling, radio box, fuel tank, wedge rudder, flexi-shaft assembly, waterscoop, water, fuel and exhaust silicone, rudder linkages, throttle cable and linkages, rubber bellows,  hatch fixings, balanced sharpened bronze propeller and aerial. This is everything needed to build this boat excluding radio control and glue.   £380.00
PUMA High speed deal
Consists of Puma boat with racetuned Zenoah  Petrol pullstart racing engine  6.8 bhp engine, special watercooled exhaust adapter, stainless steel watercooled silenced tuned pipe, racing motor mounts, flexishaft and wedge rudder assembly with built in waterscoop, epoxy/glass radio box, stainless steel collet type flex hex coupling, fuel tank, quick release hatch clips,  balanced sharpened bronze racing propeller, aerial, radio linkages, rubber bellows,  Prototype runs at 65 plus mph (100 kph)  Normal price .  £792.00 , Special price £735.00.
COUGAR
Cougar, identical to the Puma design except for the size.....36" ( 940mm)  long deep V . Designed for direct drive 6.5 to 7.5cc engines (.40 to .45) or gear drive 3.5cc engines.
    Gelcoated fibreglass hull and deck joined with engine cover. £129.00.
   Hardware consists of flexi-shaft, strut, tube, brackets, CNC  machined wedge rudder with built in water-pickup and brackets.  £68.00,  Epoxy glass lowline  radio box £13.00  Quiet engine mount £12.20 .
COUGAR  Low cost deal
  Cougar with SC46(7.5cc)  marine engine, steel manifold(header), silenced tuned pipe, quiet engine mount, coupling, radio box, fuel tank, wedge rudder, flexishaft assembly, water, fuel and exhaust silicone, all radio linkages, rubber bellows,  hatch fixings, balanced-sharpened bronze propeller and aerial .    £325.00
COUGAR  FSRO 3.5 racing deal
Cougar with Flexishaft assembly, cnc machined wedge rudder with waterpickup, quiet engine mount, Epoxy radio box, fuel tank, Coupling, Special FSRO gearbox for CMB 21 Valvola, CMB 21 Valvola engine, Exhaust header (manifold), Watercooled stainless steel tuned pipe, Balanced sharpened Octura prop, water fuel and exhaust silicone tubing, hatch fixings and aerial.  £650.00.
 楼主| 发表于 2004-12-25 21:12 | 只看该作者
PRESTWICH DEEP VEE and SPORTS BOATS
APACHE CIGARETTE 57. Scale model of the fullsize racing Offshore powerboat CIGARETTE Deep Vee. 56" (1420mm) long x 15.5" (390mm) wide. This is a big boat that can be powered by 15cc glow (nitro) engines or 22 to 26cc Petrol (gas) engines. This boat can be used in the roughest water conditions but will be very fast on calm water too. Normally uses a flexi shaft/surface drive for scale appearance and high speed.
Moulded in coloured gel-coated Fibreglass. Very strong construction. Hull and deck is pre-joined with moulded fibreglass engine cover.   £165.00.
 楼主| 发表于 2004-12-25 21:13 | 只看该作者
以下是N次世界冠军的著名的3款FSRV
AT THE FIRST 2004 MAJOR RACE MEETING THAT WAS COMPLETED IN THE UK, the Tornado4 with Prestwich pipe and 2227 Mocom propeller won by 7 laps!  At the first 2004 International in Haarlem Holland the Tornado 4  had the fastest lap-times in 15cc by almost 1 second per lap !  At the last UK race before the World Champs the Tornado EVO4 won by 12 laps ! At the World Championships in Velenje 2004 the Tornado 4 was the TOP QUALIFIER in 15cc.
TORNADO EVO4. click here for more pics
The Tornado EVO4 is a new design 15cc FSRV15 boat from Dave Marles. The hull has been redesigned to make it ride very light on the water for high speed and good stability and the shaft and rudder position changed to improve cornering speed.  To get the best stability, the hull rear is flattened from just in front of the propeller to enable a very shallow shaft angle to be achieved, the centre rail offset has been changed, and to improve the speed and stability the torque wedges are changed so that they do not touch the water until needed. Speed is faster through the corners due to an alteration to the front V of the hull and the changes to the chines.   The fuel tank sits lower in the Tornado EVO4 and the radio compartment is larger for ease of radio fitting. The deck has been redesigned to give low hull lift for good stability at full speed.
  TORNADO 4
Top FSRV15cc qualifier at the 2004 World Championships in  Slovenia.  116 cm long, 34 cm wide.
TOR3 Tornado 4 VACUUM The hull is moulded from 5 layers of 290 grm glass and epoxy  and made with vacuum for very high strength. The boat is made in a ceramic mould and is cured in an oven for maximum strength. £180.00
280 Euro
TOR4 Tornado 4 moulded from epoxy carbon/kevlar and made with vacuum for very high strength and stiffness. Carbon Kevlar boat is strong and very stiff and lightweight. £225.00
350 Euro
TOR5 Tank/engine cover in epoxy glass £25.00
  40 euro
TOR6 TORNADO 4, vacuumed epoxy/glass, JOINED TOGETHER with tank and engine covers and bulkhead (partition) patterns. £265.00
400 Euro
TOR7 Tornado 4 vacuumed epoxy carbon/kevlar JOINED TOGETHER with epoxy glass engine and tank cover and bulkhead (partition) patterns. £295.00
450 Euro
CW4 Carbon wing. Special strong wing for the Tornado 4 £22.00
Tornado EVO4 raced in the World Champs was epoxy vacuum glass boat with tank cover is using tuned CMB91RS Tuned by Prestwich and 2227 Mocom propeller.  Other parts being used.  BR88 propshaft, WP24 rudder, PT7 fuel tank, CS5A tuned pipe at 290mm length, GA1A waterscoop, PT14 tank mounting,  CNC2 coupling, XX4A radio hatch cover, GA13 servo mounting tray, 2 trim tabs GA17, FC3 float chamber, carbon wing.
N.B.  Where Euro prices are shown they are approximate based on recent exchange rates.
 楼主| 发表于 2004-12-25 21:15 | 只看该作者
SPYDER2
The new FSRV 7.5cc boat. This new boat is an improvement over the original World Championship winning FSRV7.5 Spyder with modifications which  improve stability especially with bigger propellers. The basic concept of the hull is similar to the Vortex but it is longer with tiny front chines added to keep the nose up in the turns for higher cornering speed. The right side chines are changed and the boat will run in a straight line without any left rudder which contributes to the higher top speed. Winner of the 2000 World FSRV7.5 championships, 2002 FSRV7.5cc World Championships and almost every International FSRV 7.5 race since then..
SPY3 Spyder 2 VACUUM moulded from epoxy/glass  for very high strength and durability in crashes. Vacuumed boat has more layers of glass for the same weight of boat to give stiffness and strength.  £140.00
SPY4 Spyder 2 moulded from epoxy carbon/kevlar and made with vacuum for very high strength and stiffness. Carbon Kevlar boat is strong and very stiff and lightweight.  £174.00
SPY5 Tank/engine cover in epoxy glass . £22.00
SP6 SPYDER 2 Vacuumed glass and JOINED with tank/engine cover and partitions. . £220.00
CW1 Carbon wing. . £20.00
Prototype used Spyder 2 epoxy vacuum glass boat with tank cover and tuned CMB45 Evo2 on the Prestwich GB2A gearbox and 2026 Mocom propeller.  Other parts used.  BR87 propshaft, WP23 rudder, PT4A fuel tank, CS20 tuned pipe at 210mm length, GA1A waterscoop, PT13 fuel tank mounting,  CNC1 coupling, XX4A radio hatch cover, GA13 servo mounting tray, 2 trim tabs GA17, FC2 float chamber, CW1 carbon wing.
 楼主| 发表于 2004-12-25 21:16 | 只看该作者
Lightning 2
The latest FSRV3.5 boat from the designer of the last 2 World Championship winning FSRV3.5cc boats.  The version 2 is modified to the exact specification of Dave Marles Lightning that he has developed  over the last 3 years.  Modifications have been made to the rear chines and wedges and to the anti-torque angles of the hull. This is the fastest most stable 3.5cc FSRV boat around. Very easy to build and drive, this is 'state of the art'. Designed for geared 3.5cc (.21) engines and submerged drive. This boat can be used with CMB21 Valvola and gearbox or CMB21 LS or similar high powered .21 engine on a gearbox. Fastest 3.5 boat at every race entered in the past 3 years.
LT3 Lightning 2 VACUUM moulded from epoxy/glass for very high strength and durability in crashes. Vacuumed boat has more layers of glass for the same weight of boat to give stiffness and strength.  £136.00
LT4 Lightning 2 moulded from epoxy carbon/kevlar made with vacuum for very high strength and stiffness. Carbon Kevlar boat is strong and very stiff and lightweight.  £163.00
LT5 Tank and engine cover in epoxy glass . £23.00
LT6 Lightning 2 vacuumed and JOINED with deck openings cut out and hatch cover included with bulkheads. . £210.00
CW1 Carbon wing/handle . £20.00
SW1 Pair of Carbon side wings . £20.00
Prototype used Lightning2 epoxy vacuum glass boat with tank cover and tuned CMB21 Valvola on the Mocom Valvola gearbox and 1924 Mocom propeller.  Other parts used.  BR87 propshaft, WP23 rudder, PT3A fuel tank, CS11 tuned pipe at 185mm length, GA1A waterscoop, PT13 tank mounting,  XX4A radio hatch cover, GA13 servo mounting tray, 2 trim tabs GA17, FC1 float chamber and carbon wing CW1 and side wings SW1.
发表于 2004-12-25 21:39 | 只看该作者
看这些船和看杂志上美女的感觉差不多也只有看的份
发表于 2004-12-25 22:27 | 只看该作者
你有卖吗?500元一条呵。:em15:
发表于 2004-12-25 22:28 | 只看该作者
看不懂啊!
发表于 2004-12-25 22:29 | 只看该作者
:em26:
 楼主| 发表于 2004-12-25 22:38 | 只看该作者
大家乐  在 2004-12-25 10:27 PM 发表:
你有卖吗?500元一条呵。:em15:
给冰淇淋发消息吧!
发表于 2004-12-25 22:44 | 只看该作者
方舟  在 2004-12-25 10:38 PM 发表:
给冰淇淋发消息吧!
:em00::em00::em00::em00:
发表于 2004-12-25 23:40 | 只看该作者
好船:em07:
发表于 2004-12-26 01:37 | 只看该作者
大飞0034  在 2004-12-25 11:40 PM 发表:
好船:em07:
:em07::em07::em26::em26::em26::em26:
