查看: 2256|回复: 13
狗1开机后死机-显示几个字母【问GOPRO官网了有回复】修好了
发表于 2013-6-6 20:59 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
之前也经常死机  显示SOS
今天一开机就变这3个字母了  啥意思   哪位大神知道
和卡没关系  不插也这样
电池没关系  换USB供电也这样
根据提示 说TV口的问题  测了一下  不连通   直接用3根飞线焊上。。解决了。。修好了。。就是那个座子被我焊烂了  反正也不用
问了官网(不到半小时内就回复了  咱这凌晨 他们那中午 这效率。。还真重视用户。。)
We are sorry to hear you are getting the TEL message.
If your LCD screen is displaying the 'tEL' icon, it is to indicate that the camera is connected to a TV via the HD or AV component cables for photo\/video playback.
If 'tEL' is being displayed while no HD or AV cable is connected to the camera, then there is a fault.  It could be a one time glitch being caused by a bad connection in the TV port in the camera.  Please try the following:
Remove the battery from the camera.
Insert and remove the HD and AV component cables from the TV output ports to clear up any possible faulty connection.
Reinsert the battery into the camera.
Power on the camera once more.
If the camera is still displaying 'tEL' with no cables connected after following the above steps, then unfortunately it sounds like there could be a fault with the camera, and we'll need to go ahead with replacing your unit under warranty.
To get the process started, can you please reply with a copy of your purchase receipt to show you are within the warranty period, the camera's serial number located inside the battery compartment, and also follow the below link to enter your return shipping info for the replacement camera:
Enter Address Here.
Once we hear back, we'll be able to provide you with a RMA (returns authorization) and returns instructions.
Our apologies for the inconvenience, but we'll do our best to get you a fully functioning replacement as soon as possible.
Many Thanks,
Josh M
GoPro Support
gopro.com\/support
看来是上面那个TV输出的接口出问题了。。 那就悲剧了。。。。GOPRO认为我插东西上去了。。。就定在那了。擦。。。。
附大卸八块图:
------------我是分割线  下面说TX100的情况------------
手痒  想拆TX100  改个外接供电    鄙人水平有限   感觉很难 就又装了回去
结果 开机后 电源灯亮  屏幕显示  3秒后自动关机。。
这是坏的第N台机了。。前面战死的弟兄还有Zi6 、ZI8、CLIP-HD 、纽曼WD100。。。
发表于 2013-6-6 21:21 | 只看该作者
沙发,真心不知道撒意思
发表于 2013-6-6 21:38 | 只看该作者
狗 3问题还真是多
发表于 2013-6-6 21:39 | 只看该作者
看不懂
发表于 2013-6-6 21:43 | 只看该作者
SOS  是救命的意思吧,,呵呵,,这是摄像机正在厂家求救的一个自救过程。。。
发表于 2013-6-6 21:47 | 只看该作者
我的狗2也刷悲剧了,还是美国代购的,没办法返修了吧。。。
发表于 2013-6-6 21:54 | 只看该作者
把人家拆成这样很反感,叫你电话联系。Tel
 楼主| 发表于 2013-6-6 22:21 | 只看该作者
。。。谢谢各位帮顶。。7楼真幽默- -。。。。哈哈
我的保修期过了。。。而且换过镜头  炸过。。没过保修期也不给修了。。哈哈
这是一代。。。
发表于 2013-6-6 23:00 | 只看该作者
tel 是不是让咱们给服务打电话?
发表于 2013-6-7 01:14 | 只看该作者
LZ把你的烂货通通都发过来 我帮你修修看 狗1刷一下固件试试
发表于 2013-6-8 17:24 | 只看该作者
这哪儿是“战死”啊,分明是非战斗减员,被长官整死的。
发表于 2013-6-9 09:57 | 只看该作者
我遇到的狗2升级问题也是发邮件给官网得到解答的,24小时内就收到解答回信,赞一下狗公司
发表于 2013-12-22 01:28 | 只看该作者
唉~~我也刷了固件,结果就出现这个问题了,真是手贱的后果啊!!!
发表于 2013-12-29 08:38 | 只看该作者
内容
