查看: 1393|回复: 11
如何讓引擎達到有效的冷卻效果!
发表于 2013-11-24 11:28 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
Peter Folmer, who at first sent me in an engine with severe overheating symtoms, gave me permission to publish his data and experience, so others might benefit.
Here goes:
Repair engine, run in "normal glow engine fashion with cowled engine" in a 3D airplane.
The cylinder had turned all shades of yellow. purple, blue and gray, indicating engine temperatures in excess of 300°C. Piston and cylinder were OK, but crankshaft, conrod and all bearings needed to be replaced.
The cylinder head anodize had lost a few shades of hue (color had bleached) due to the heat.
以上是飛友在描述引擎發生嚴重過熱的情況
還有發生過熱引擎出現的變化
這顆引擎高溫達到高溫達到300度
內部機件都已損壞!!該換都換了
其他就沒太多的重點
以下就是重點了
After repairs, he installed a Venom temperature gage, and these are the results:
這是未安裝導風版引擎溫度的狀態
No cowl:
prop 18x6, rpm 9000 static, max temp. 132°C (static and 3D)
prop 16x12, 8000 rpm static, max temp 118°C (Aerobatics)
這是使用導風版後的情況
Peter then prepared baffling and a cylinder jacket made from aluminium air ducts. For air extraction from the cowl, louvres were made, and they proved very effective.
In flight: max temperature of 95°C (outside air was at 10°C, so quite cool)
ground running: max temp 100°C
Ground running, changing from 1/2 to 1/1 throttle vice versa, the temperature rose to 85 degrees. when the engine returned to idle, the temp. dropped very quickly to 69°C
For Images of his setup, see next post (soon)
大家也一起來分享您是如何讓引擎達到散熱的方法
以上文章來自PRME Engines User Community Forum
 楼主| 发表于 2013-11-24 11:31 | 只看该作者
下面是我根据这个帖子自己做的散热器整流板,已经飞了5-6起落暂时无发现 过热情况,继续测试有待观察!
发表于 2013-11-24 18:48 | 只看该作者
在模型世界这本杂志上见过详细的散热过程 和楼主差不多
 楼主| 发表于 2013-11-24 20:18 | 只看该作者
从遥控技术上拍的给大家分享下。
 楼主| 发表于 2013-11-25 10:40 | 只看该作者
全部原文。
发表于 2013-11-25 12:16 | 只看该作者
LZ这是那一期的模型世界啊····?
 楼主| 发表于 2013-11-25 12:59 | 只看该作者
爱飞的耗儿 发表于 2013-11-25 12:16
LZ这是那一期的模型世界啊····?
2012.10  遥控技术
发表于 2013-11-25 18:02 | 只看该作者
很实用
发表于 2013-11-25 21:13 | 只看该作者
技术贴 要顶为留名
发表于 2013-11-27 11:06 | 只看该作者
好东西但是我没有研究过。
发表于 2013-11-28 15:34 | 只看该作者
这个的确要注意到
发表于 2014-6-11 16:30 | 只看该作者
很实用
