查看: 2468|回复: 5
Mobius Actioncam集中讨论帖
发表于 2015-12-7 13:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
Mobius actioncam的专属PC端应用程序 Msetup.exe 最新版本为3.0.6.2
繁体中文版官方下载地址:http://www.mytempfiles.info/mobius/mSetup_TW.zip
Mac 64 bit :下载地址
The Mobius ActionCam is one of the most sophisticated mini cameras around. Measuring 1 3/8″ x 2 1/2″ x 3/4″ inches and weighing only 1.4 ounces, this camera can easily fit in any pocket, but press record and you will capturestunning 1080 HD video quality normally only found on devices 5 times the size. (compatible with Windows based PC’s and Mac computers)
Video Quality The Mobius can record in beautiful 1080P H.264. HD video quality at 30 frames per second. At the highest video quality, the bit rate will be nearly 18,000 kpbs in wide angle recording. There is also a 720P 60 frames per second option suitable for extremely fast action recording, and WDR (Wide Dynamic Range) recording for low light scenarios. A Time Lapse mode, where the camera will automatically take Time-Lapsed still images and Time-Lapsed video is also included. The Mobius can also be configured for motion detect recording; allowing the user to set the sensitivity.
Battery Life With thenew increased capacity battery (820mah), Mobius can now record for just over 2 hours! Add a power bank to increase the battery life. The Mobius Actioncam is capable of recording live video while connected to an external power source as well, such as a driving recorder.
Audio Quality The Mobius records excellent quality audio at 512 Kbps PCM (CD quality). Audio can be turned off as well via configuration utility.
Use it as a Driving Recorder; with the Magnet Mount and car adapter (Pro Package), the Mobius makes an effective dash cam. Camera can be configured that, as soon as the Mobius is plugged into the car power adapter it will start recording, no need to press record. With the Mobius’ video quality and wide angle view, you can read any license plate on the road with ease. Loop Recording mode is a very helpful feature, you no longer need to worry if you have enough memory!
Packages, Mounts and Accessories; Included with the Basic Mobius Package is an attachment sleeve, 1/4020 threaded mount, a Velcro mount and a USB cable & car charger. Add 16GB of memory and you have the Basic Mobius 16G Package. Note: we use only quality Kingston micro SD cards. If you want the full benefit of the small size of the Mobius with additional mounts like the Magnet Mount and the “V” mount for bar mounting, 1/4-20 standard screw mount, then you want the Mobius ActionCam Pro Package. Add the Weather Cover for those damp, messy conditions and you have the complete Mobius ActionCam Pro16 Package. Optional accessories are available: Magnet Hat/visor clip, adhesive backed Magnet Mounting Disc, Adjustable (helmet) Mount, Weather Cover, Magnet Mount for archery bow mount, Video-Out Cable, & USB-OTG Cable to connect to Android devices.
About us, we are one of the official resellers/co-developers of the Mobius Action Camera in the US. We also offer our unique mounting options as well as the Weather Cover and other accessories for the Mobius Camera. Our goal is to take full advantage of the small size of the Mobius camera and keep the mounting options as small and compact as possible, thus the unique Magnet and “V” Bar Mounts. We pride ourselves on providing quality products, sales, service & support. We also ship world wide.
发表于 2015-12-7 20:15 | 只看该作者
感谢老和,啥时候翻个中文版的吧
发表于 2015-12-8 14:23 | 只看该作者
支持老何,尽快翻译。
发表于 2015-12-22 14:20 | 只看该作者
牛逼
发表于 2015-12-22 14:21 | 只看该作者
牛逼
发表于 2016-3-4 13:53 | 只看该作者
我的808 现在电脑上无法识别出U盘模式,可实际东西是好的,录像什么的都没问题
