查看: 1202|回复: 4
1/8油大脚车
发表于 2006-7-11 11:25 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
:em21:
    Type: Monster Truck
   Length: 540mm
   Width: 300mm
   Wheelbase: 365mm
   Weight: 6kg
   Tyres size (F/R): 175mm
   Tyres Width: 105mm
   Chassis: Double-deck aluminum
   Suspension: 4-wheel independent
   Drive Train: F/R diffs, 2-speed with slipper clutch
   Tire Type: Claw rubber tires w/foam inserts (preglued)
   Motor or Engine:27 engine
   Radio: 3-Channels LCD Digital Proportional Controller
   Servos: 2 x 6kg (steering) 1 x 3.4kg (throttle/brake,backward)
   Speed: 70 KM
   Kit/RTR: RTR
   Shock Type: Oil-filled, coil over Mega Shocks with threaded collars
   Body: Factory-decorated polycarbonate
   Ball Bearings: Complete
   Fuel Tank Capacity: 171cc
   Electric Start
:em26::em26::em24::em00:
点击查看详情
发表于 2006-7-17 15:36 | 只看该作者
国产LST!!
发表于 2006-7-17 18:04 | 只看该作者
全套上油就跑,价格控制在1800以内就好了。
发表于 2006-7-18 22:14 | 只看该作者
厉害!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
发表于 2006-7-23 03:02 | 只看该作者
抄袭版lst......
