查看: 1109|回复: 1
BLHELi支持的电调变少?!
发表于 2017-2-17 21:41 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
如图 支持的电调变少了  老版本能看到的型号新的看不到了?!
发表于 2017-3-6 23:26 | 只看该作者
Changes in 16.6.14.9.0.0:
General:
Added BLHeli_S 16.6 hex files.
Added BLHeli Atmel and SiLabs 14.9 hex files.
BLHeli SiLabs:
Removed revision 14.4 – 14.8 hex files for “Flycolor Fairy 30A” due to a FET timing bug only relevant for this ESC.The issue was introduced with BLHeli rev. 14.4 and caused excessive heat. Fixed in BLHeli revision 14.9.
Added “Servoking Monster 70A Pro” ESC data.
https://blhelisuite.wordpress.co ... lhelisuite-history/
https://github.com/4712/BLHeliSuite/releases
